165
OxygenOS 10.3.7 for the OnePlus 6 and 6T
  1. themountaineagle
    Froyo Nov 30, 2020
  2. Danielarr45
    Honeycomb Nov 30, 2020
    Danielarr45 , via OnePlus 6 , Nov 30, 2020 :
    I'm glad that we are finally getting overdue updates, but can anyone explain to me why Apple and Google, with much larger exo systems, push out updates much quicker and across multiple generations of devices much better than OnePlus?
  3. ankkyankit11
    Froyo Nov 30, 2020
  4. surendra91
    ironass and Caoimhín like this.
  5. ItsRavi25
    Jelly Bean Nov 30, 2020
    ItsRavi25 , via OnePlus 6T , Nov 30, 2020 :
    As mentioned in the first post and throughout this thread, IT'S INCREMENTAL ROLL-OUT, it will take time to reach every device as the updates are release randomly.
    It will take 2 weeks more to roll out completely.
    For faster updated you may follow this process, both this method and OTA are same,🙂
    Use Oxygen Updater from play-store
    https://play.google.com/store/apps/details?id=com.arjanvlek.oxygenupdater
    Or
    You can install it manually (Incremental update)
    OnePlus 6
    https://otafsg1.h2os.com/patch/amaz...22.J.49_OTA_048-049_patch_2011161942_7603.zip
    OnePlus 6T (Incremental update)
    https://otafsg1.h2os.com/patch/amaz...9_OTA_048-049_patch_2011161944_ff7f5b9593.zip
    OnePlus 6T (Full update)
    https://otafsg1.h2os.com/patch/amaz...xygen_34.J.49_OTA_049_all_2011161944_5529.zip
    Download the latest available OOS firmware zip from above.
    Get the full firmware package from above for the OnePlus device and transfer the ROM file to the internal storage or phone storage. Place the zip file outside every folder.
    Now go to Settings app > visit System updates > tap on the top right settings icon > choose Local Upgrade option.
    The Local Upgrade option will search for an upgrade package.
    Once you see an upgrade package, tap over it and then hit the install option.
    The device will automatically reboot and perform an upgrade. First boot may take a while.😇
    Auristic and ironass like this.
  6. BeingIncog
    Nougat Nov 30, 2020
    Caoimhín and Starcommander like this.
  7. ItsRavi25
    The solution is already mentioned many times in thread.
    And various thread are already created.
    Use search options.
    Here is the solution once again
    Goto to settings > search > OnePlus > scroll down you will find 2 apps
    1) OnePlus Membership ( uninstall the update)
    2) OnePlus Account.
    Clear the cache and storage of both app and reboot your device.
    Done😇
  8. BeingIncog
    Nougat Nov 30, 2020
    BeingIncog , Nov 30, 2020 :
    No no no, but your statement means to use more ruder terms...
    Caoimhín likes this.
  9. BeingIncog
    Nougat Nov 30, 2020
  10. BeingIncog
    Nougat Nov 30, 2020
    I think some other mod saw it.
  11. Caomhin
    OnePlus 9 Series Expert Community Expert Nov 30, 2020
    Caomhin , via OnePlus 6T , Nov 30, 2020 :
    As per @B_Wrath pinned post on 10.3.3 thread
    https://forums.oneplus.com/threads/oxygenos-10-3-3-for-the-oneplus-6-and-6t.1218405/
    If you can Backup your Download Folder
    Delete the data and cache of downloads app and download manager. This should fix the problem.
    Q: How to access the downloads and download manager app?
    A:
    Step 1: Unlock your phone.
    Step 2: Open app drawer and locate settings app / bring down the QS panel and click on the gear icon.
    Step 3: Click on the search tab on top of the settings app.
    Step 4: Type "downloads" and then click on the app. Clear it's cache and storage which is under the storage tab.
    Step 5: Type "download manager" and then click on the app. Clear it's cache and storage which is under the storage tab.
  12. Mihir09 , via OnePlus 6 Midnight Black , Nov 30, 2020 :
    Anyone has noticed after this update the performance of the device decreased in huge margin.. opening closing apps takes longer time.. battery backup has also decreased.. and ocassionally phone is lagging so much..
  13. B1606714663706
    Cupcake Nov 30, 2020
    B1606714663706 , via OnePlus 6T , Nov 30, 2020 :
    Maine May 2019 me One Plus 6T mobile kharida tha aur wo ek saal hone se pehle hi hang hona start ho gya Battry drain hona suru ho gya aur Uske photo gallery ko open karo to bahut time lagta tha aur same issue Screenshot lene k baad Photo open me time lgta tha so maine costumer care me baat karke sare settings kar liye aur Mobile ko Factory reset b kar diya aur thode din normal raha but uske baad b issue waise ka waise hi h abhi b mai Is mobile ko kharidkar Pachhata raha hu aur abhi struggle kr rha hu...😭😭
    Kripya jald se jald help krne ki koshish kare🙏🏻🙏🏻🙏🏻
    Thanks&Regards
    Mukesh Nabiyal
    (edit by moderator)
  14. J.Khaptawala
    Eclair Nov 30, 2020
  15. ItsRavi25
    You're are incorrect , I didn't face any issue that you have mentioned.
    I am getting 10+SOT with smooth performance.
    How did you calculate the performance margin .😂
    The device performance is based on your device settings and the app you use.
    And same for the battery it depends upon the apps and the optimization of apps.😇
  16. ItsRavi25
  17. Pratik78 likes this.
  18. Imcoolkarni
    Donut Nov 30, 2020
    Q1575609574267 likes this.
  19. M1552708808222
  20. Caomhin
