165
OxygenOS 10.3.7 for the OnePlus 6 and 6T
  1. P1607353601024
    Cupcake Dec 7, 2020
    P1607353601024 , Dec 7, 2020 :
    Thank you for the detailed reply
    I have checked and I have the 1st October update (and if clicked to update it says my device is up to date)
    We have the same version of Play Services
    The Play Store is different though my version is 23.0.21-21
    It is indeed unusual. I didn't notice it straight away because I hadn't used Google Pay for a few days and then I tried to pay in a shop and I couldn't.
    I haven't installed anything that wasn't either a Google Play prompted update or a System Update prompt. So it is indeed odd that it just "broke" since everything seems to be up to the correct date. And as I said everything worked perfectly fine before the 10.3.7 update.
    Caoimhín likes this.
  2. Auristic
    Lollipop Dec 7, 2020
    Auristic , Dec 7, 2020 :
    And of course NFC was on... Sorry, no clue.
    ItsRavi25 and Caoimhín like this.
  3. P1607353601024
    Cupcake Dec 7, 2020
    Yeah NFC was on.
    It really is an odd one but it is a major problem so if anyone here has any suggestions I would appreciate the help.
    Caoimhín and Auristic like this.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Dec 7, 2020
    Caomhin , via OnePlus 6T , Dec 7, 2020 :
    There is a possible solution here to recertify the phone. Follow the steps on the site and see if it can help.
    How to fix “Device is not Play Protect certified” error
    https://www.technobaboy.com/2020/03...k if your device,your device is not certified.
    If the above does not work. Only other issue I can think of is that something between Android and Google is not functioning. You may have to do a Backup of the phone and then do a full Erase All Data factory reset.
    Bit extreme I know, but currently can't think of anyway of fixing Google security protocols.
    Let us know how that works out for you 👍🏻
  5. Z1538239228958
    Donut Dec 7, 2020
    Z1538239228958 , via OnePlus 6 , Dec 7, 2020 :
    How didi you resolve those issues where the applications were closing unexpectedly
    D.Sai Suhail Baba likes this.
  6. jaganstan
    Cupcake Dec 7, 2020
    jaganstan , Dec 7, 2020 :
    Hii..Bro .One issues.. i tryedd what said but it says updated instalation failed
    please help..
  7. Caomhin
    What version of OOS are you on currently?
    What phone model do you have?
    And what version did you download?
    ItsRavi25 and ironass like this.
  8. jaganstan
    Cupcake Dec 7, 2020
    my phone currently version
    Phone model Oneplus 7
    now download version ..10.3.7.GM57AA
  9. Lalith_Roxx
    Donut Dec 7, 2020
    Lalith_Roxx , Dec 7, 2020 :
    Anyone still facing the Camera shutter lag? There is a 1-2 second lag while taking a picture on my OnePlus 6
    ianmgkc likes this.
  10. K1577555224305
    Honeycomb Dec 7, 2020
    K1577555224305 , Dec 7, 2020 :
    Any one having issue with erratic colors after 10.3.7 . If the screen changes colors from amoled to vivid or natural or wide angle gamut on its own and changes back on its own. 🤷 its quite visible ( not subtle) as it takes off the minds and disrupts attention.
  11. ironass
    kjjm, Auristic, drl431 and 2 others like this.
  12. zigzigzig
    Cupcake Dec 7, 2020
    zigzigzig , Dec 7, 2020 :
    since Ive updated last night to this release my phone will reboot on 1/2 the apps I try to open.
    anyone have any ideas on how to resolve or have the same problem?
  13. G_Matthew_Sweeny_GwnH
    Cupcake Dec 7, 2020
    G_Matthew_Sweeny_GwnH , Dec 7, 2020 :
    The last 3 updates haven't fixed the call dropping issue. Wifi and data will drop randomly and my service is spotty in areas it use to be good in. This last update just made it worse than ever. I would like to see previous issues fixed before new ones are pushed.
  14. rakeshgergal
    Froyo Dec 7, 2020
  15. Caomhin
    now download version ..10.3.7.GM57AA[/QUOTE]
    From what I can see is that the last version of 9 before 10 is OS 9.5.8. GM57AA so you will need to install this version first as it contains files required to update to 10. Once update to OS 9.5.8. GM57AA you can then update using the version of 10 you downloaded, the one that failed.
    You can download OS 9.5.8. GM57AA from here
    https://piunikaweb.com/2019/11/19/oneplus-7-series-7-7-pro-7-pro-5g-software-update-index/
    Auristic and ItsRavi25 like this.
  16. Caomhin
  17. Caomhin
    Please check the solution by @ItsRavi25 in the Community post below.
    https://forums.oneplus.com/threads/changing-hues.1355138/
    Also try Enable or Disable DC Dimming as well. See if that helps.
  18. Caomhin
    If the last 3 updates haven't fixed it, there may be something more fundamental at fault. Have you tried backing up your phone and then do a full Erase All Data factory reset?
  19. ironass
    ironass , Dec 7, 2020 :
    In that case it is my fault for not going back through the conversation far enough. OMG... I am, "The Walking Unread!" :eek:
