165
OxygenOS 10.3.7 for the OnePlus 6 and 6T
  1. mohd_areeb
    Honeycomb Dec 8, 2020
    D.Sai Suhail Baba likes this.
  2. O1589611149496
    Cupcake Dec 8, 2020
  3. mohd_areeb
    mohd_areeb , via OnePlus 6 , Dec 8, 2020 :
    Yea, More bloatware is there in OnePlus 7 than any other series.
  4. Kushal_sai
    Eclair Dec 8, 2020
    Kushal_sai , via OnePlus 6 , Dec 8, 2020 :
    Could you upload the screenshots I couldn't get u
  5. dashxdot
    Gingerbread Dec 8, 2020
    dashxdot , via OnePlus 6T , Dec 8, 2020 :
    Settings> Apps and notifications > See all apps > OnePlus membership> 3 dots on top right corner > Uninstall updates.
  6. C1542526158633
    Eclair Dec 8, 2020
  7. Auristic, Pepa1977, drl431 and 6 others like this.
  8. ironass
    Lollipop Dec 8, 2020
    ironass , Dec 8, 2020 :
    I blooming love that attachment! :D
  9. kamdab01625
    Cupcake Dec 8, 2020
  10. rakeshgergal
    Froyo Dec 8, 2020
    rakeshgergal , via OnePlus 6T , Dec 8, 2020 :
    after 10.3.5 my oneplus 6t lags , battery draining issue and now settings app crash ...its time to trash my phone 🤮🤮just for name sake plz don't provide updates
  11. R1544846000138
    Cupcake Dec 8, 2020
  12. Caomhin
    OnePlus 9 Series Expert Community Expert Dec 8, 2020
    Caomhin , via OnePlus 6T , Dec 8, 2020 :
    Have you considered it may be other 3rd party apps causing the issue. To find out if it is. Go into Safe mode, run through the settings and see if the crash in Safe mode. If it doesn't then some 3rd part app is causing issues.
    Try going into Safe Mode. And remove any recent app installs or updates that may be causing the issue. Also backup all your data while in Safe mode.
    Method 1
    Press the power button to bring up the power menu, now long press Power Off option you will get the option to boot into safe mode. Select OK
    Method 2
    Turn off your Android device by holding the power button and selecting the power off option from the menu.
    Once your device has been powered off, long press the power button to turn it back on and wait till you see the device manufacturer or the Android logo.
    Once you see the logo, press and hold the volume down button until your device reboots.
    Release the power button once your device has rebooted and you will now be entered into the safe mode.
    To get out of Safe Mode
    Hold the power button on your device until you get the power off menu.
    Select the restart option from the menu.
    Your device will now be rebooted and exit from the safe mode and boot into the normal mode.
    Auristic, dashxdot, drl431 and 2 others like this.
  13. Ravindra1991
    Donut Dec 8, 2020
  14. Caomhin
    Do the following, it should fix the issue.
    Uninstall updates for OnePlus Membership App then Clear the App info Cache and App info Storage.
    Also clear the App info cache and App info storage of the OnePlus Account App and then reboot the phone.
    Auristic, drl431 and ItsRavi25 like this.
  15. Kushal_sai
    Eclair Dec 9, 2020
    Kushal_sai , via OnePlus 6 , Dec 9, 2020 :
    Thank you
    dashxdot likes this.
  16. Kushal_sai
    Eclair Dec 9, 2020
    Sorry to bother you but I found another bug the cloud services app is a problm
    Even my network is On it shows network error!!!
  17. ItsRavi25
    Jelly Bean Dec 9, 2020
    ItsRavi25 , via OnePlus 6T , Dec 9, 2020 :
    Goto settings> search cloud > open cloud services app info > force stop and clear the cache and storage > reboot your device.
    Caoimhín likes this.
  18. Vignesh_Sreekrishnan
    Cupcake Dec 9, 2020
    Vignesh_Sreekrishnan , Dec 9, 2020 :
    Is there anyone else facing this issue after updating to 10.3.7. in their OnePlus 6t ? Please help in resolving this problem.
  19. Najeeb_Aslam
    Eclair Dec 9, 2020
    Najeeb_Aslam , via OnePlus 6 , Dec 9, 2020 :
    Hi,
    I have something to ask from community that Flashlight with back camera on whatsapp video call didn't work but it works with Huawei and Samsung smartphones is it bug or missing feature or it with A10?
