165
OxygenOS 10.3.7 for the OnePlus 6 and 6T
  1. rhyd1am
    KitKat Dec 12, 2020
    rhyd1am , via OnePlus Community App , Dec 12, 2020 :
    Just out of interest, how can you call it a buggy update when you haven't even tried it yourself? Not a single issue on my 6t, and the only 2 common issues I'm seeing is with red cable club and chrome. Both of which have been solved and can be fixed in a matter of seconds 🤷‍♂️
    drl431, kjjm, Caoimhín and 4 others like this.
  2. Tee_Eee_Bee
    Ice Cream Sandwich Dec 12, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Dec 12, 2020 :
    If you haven't already, try resetting your network adaptor and see if that helps:
    System > Settings > Reset options > Reset Wi-Fi, mobile and Bluetooth
    drl431, Caoimhín, Auristic and 2 others like this.
  3. dashxdot
    Gingerbread Dec 12, 2020
    dashxdot , via OnePlus 6T , Dec 12, 2020 :
    Try cleansing, use any of the PlayStore apps. CCleaner, Avast, Cleanmaster, preferably. Reboot and check, if not, reset your phone.
    P.S. Haven't reset my phone even once, but do these clean ups every 3 months to get to rid of the sticky cache. Phone is buttery, silky smooth, whatever you may call. Lag, hang, stutter? My 6T doesn't know these terms.
    Caoimhín and D.Sai Suhail Baba like this.
  4. Q1577255506835
    Cupcake Dec 12, 2020
    Q1577255506835 , via OnePlus 6T , Dec 12, 2020 :
    Bro,i have done all basic troubleshootong including Allow mobile data,clear catche storage.i havent done the factory reset
  5. Q1577255506835
    I have done that,still am facing problems in youtube app and google pay
  6. G1582257573825
    G1582257573825 , Dec 12, 2020 :
    хотите постоянных обновлений берите айфоны. oneplus уже не тот.
    и как же вы достали со свои redcable и постоянным мониторингом батареи , как будто вам просто больше нечем заняться.
  7. rhyd1am
    KitKat Dec 12, 2020
    Have you checked to see if your network is having issues at the moment? Definitely sounds like an issue with your network provider since you say YouTube works fine on WiFi.
    Perhaps this might help https://www.androidauthority.com/youtube-not-working-811174/amp/
    If as you say you have tried "all basic troubleshooting", and you're still experiencing the issues then realistically that only leaves the option of trying a factory reset (after backing up your data).
    drl431, ironass, dashxdot and 2 others like this.
  8. manojgudi , via OnePlus 6T Mirror Black , Dec 12, 2020 :
    Settings > search > OnePlus > scroll down you will find OnePlus Membership and OnePlus Account Apps.
    For both apps
    Click it you find three dots on top right corner uninstall the update and clear the cache and storage.
    Reboot the device.
    You are good to go.
    D.Sai Suhail Baba and drl431 like this.
  9. Q1577255506835
    No issue with my network,all the other vedio streaming apps are working properly
  10. rhyd1am
    KitKat Dec 12, 2020
    Not sure what else to suggest then to be honest. YouTube is working fine on my 6t here in the UK 🤷‍♂️
  11. Q1577255506835
    I contact oneplus 6t custumer service nd dey asked me to reset my phone,going to do dt.thanks for replyng me..hope it will be okey
    D.Sai Suhail Baba and rhyd1am like this.
  12. rhyd1am
    KitKat Dec 12, 2020
    A factory reset should definitely sort it. No problem 👍
    drl431 and Caoimhín like this.
  13. WARISALI
    Eclair Dec 12, 2020
  14. dashxdot
    Why not try uninstalling updates of YouTube and check once if haven't reset already?
    Auristic and Caoimhín like this.
  15. rakeshgergal
    Froyo Dec 12, 2020
  16. rhyd1am
    KitKat Dec 12, 2020
    I notice that you have now made 5 posts related to this. Have you actually read any of this thread? The simple and quick (around 45 seconds of your time) solution has been posted on virtually every page of this thread, by numerous community members!
    I understand that reading through a thread might well seem like a bit of work for some people (when instead they could just wait to be spoon fed the answer), but really, it is a lot quicker than posting about the problem 🙄
    Auristic, drl431, ironass and 4 others like this.
  17. rakeshgergal
    Froyo Dec 12, 2020
    rakeshgergal , via OnePlus 6T , Dec 12, 2020 :
    Lol...When nothing seems to work ...u have to keep posting about the issue ..
  18. rhyd1am
    KitKat Dec 12, 2020
    Well the solution (when followed correctly) has been working for others 🤷‍♂️
    Here is the solution (taken from @ItsRavi25 's post)
    Goto to settings > search > OnePlus > scroll down you will find 2 apps
    1) OnePlus Membership ( uninstall the update)
    2) OnePlus Account.
    Clear the cache and storage of both app and reboot your device.
  19. rakeshgergal
    Froyo Dec 12, 2020
    Y dont u open an thread where we can find only right solutions in 45 seconds😉
  20. rhyd1am
    KitKat Dec 12, 2020
