95
OxygenOS 10.3.8 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 13, 2021
    Caomhin , via OnePlus 6T , Feb 13, 2021 :
    Update to the latest Oneplus Launcher on the Playstore.
    Then clear the OnePlus Launcher App info Cache.
    Also clear your Recents App list. Then restart the phone.
    See if that helps.
    drl431, itsnealboi, dashxdot and 3 others like this.
  2. addy1me
    Donut Feb 14, 2021
  3. H1588252950399
    Donut Feb 14, 2021
    dashxdot and Skoreykom like this.
  4. H1588252950399
    Donut Feb 14, 2021
    H1588252950399 , Feb 14, 2021 :
    25, 30 -65,75 . i bought form 1y ago the phone . since then I charge it like that .
  5. H1588252950399
    Donut Feb 14, 2021
    Skoreykom
    Nice! Those look the numbers I was getting a year ago. Do you charge to 80% or just stay plugged in all night?​
    and not charging rapidly of course
  6. Skoreykom , via OnePlus 6T Midnight Black , Feb 14, 2021 :
    Yeah I've tried to keep the wear cycles down since I got the 6t.(2 years ago) I think it's made a difference to the battery life. Pretty easy to keep track of charging when the battery life is so good.
    Noticed a difference for the first few days of 10.3.8 but it's now back to where it was on .7
    Naveen_006 and H1588252950399 like this.
  7. Skoreykom , via OnePlus 6T Midnight Black , Feb 14, 2021 :
    4G
    No interest in paying extra for 5g either
    WiFi. I think it's 300 mbps down max. Fast enough not to notice any lag.
  8. GauravaRai
    Honeycomb Feb 14, 2021
    GauravaRai , via OnePlus 6 , Feb 14, 2021 :
    I agree to some extent. But I think u really need to understand depth of issue. How can two offical apps give such a stark opposite results? One says health is good other says seriously loss. This difference is like earth & sky. U can't rationalize it.
    D.Sai Suhail Baba likes this.
  9. FaleshC
    KitKat Feb 14, 2021
    FaleshC , Feb 14, 2021 :
    i personally don't use those apps.
    they aren't actually designed for consumers but for repair technicians for diagnostics purpose.
    As per your question, only OnePlus can give explanation as why their two apps fail to properly diagnose the battery health.
    I would say different apps use different api levels and different people programmed it.
  10. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 14, 2021
    Caomhin , via OnePlus 6T , Feb 14, 2021 :
    Excellent data speed on WiFi and 4G. Phenomenal SOT too.
    Can't see a reason to change the phone when it's working so well. Unless someone buys me one, or I win one. 🤣🤣
    Daughter bought herself an Galaxy S20. Have used it, and to be honest in day to day use my 6T works every bit as well, albeit fractionally slower opening apps. But not slow enough to make any discernable difference. Navigating the phone and online are almost as quick.
    I have no justification to spend money on a phone, when the 6T just works so well. Have to see how A11 works, especially with the Scoped storage and the many other features, when it is introduced, how that will have an impact on daily use. For better or worse. Will be interesting to compare.
    Might run some benchmarks on A10 and A11, before and after for comparison when it comes out.
  11. H1588252950399
    Donut Feb 14, 2021
    D.Sai Suhail Baba and Caoimhín like this.
  12. K1577555224305
    K1577555224305 , via OnePlus 6 , Feb 14, 2021 :
    The 90% is the current charge status
  13. K1577555224305
  14. Caomhin
    If its just the Community App issue. Update to the latest version from Google Playstore.
    https://play.google.com/store/apps/details?id=net.oneplus.forums
    Then clear both the Community App info Cache and App info Storage as well.
    Then make sure Notifications are enabled. After you login, click on your Profile button on the bottom right of the app, select notifications then make sure all are selected.
    If the Notification issue is more than just the Community App, then reset your permissions for all apps.
    Reset the App permissions, it may be that the app itself or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions for all your Apps again.
    Check if any or all of the above fix your issues.
  15. K1577555224305
    Nope. I wonder if I am blocked 🤷
  16. rakeshgergal
    Froyo Feb 15, 2021
  17. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 15, 2021
    Caomhin , via OnePlus 6T , Feb 15, 2021 :
    If you can access the Community App, then you are not blocked.
    You can use one or more options below to send Bug reports on the issues back to the OnePlus OOS developers.
    Feedback tool
    You can also contact bughunters@oneplus.com
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    drl431, dashxdot, ItsRavi25 and 2 others like this.
  18. ItsRavi25
    Jelly Bean Feb 15, 2021
