84
OxygenOS 10.3.9 for the OnePlus 6 and 6T
  1. quaddropop
    Honeycomb Mar 23, 2021
    quaddropop , Mar 23, 2021 :
    It won't work either, unfortunately. It says sth like "outdated version", so I got the very latest version (which is "2.39.0(1027)"), but while it installed successfully, I'm again unable to login...
    Here is a screenshot from the error message (in German, though):
    https://drive.google.com/file/d/10jrYcGbI9PSr0cLQ-PtGtRajLqlAQo57/view?usp=drivesdk
    iamrj and D.Sai Suhail Baba like this.
  2. ItsRavi25
    Jelly Bean Mar 23, 2021
    ItsRavi25 , via OnePlus 6T , Mar 23, 2021 :
    Using this version 2.38.0.....Working fine
    https://www.apkmirror.com/apk/tidal...playlists-videos-2-38-0-android-apk-download/
    If you're using 2.39.0 try some vpn to login.
  3. GauravaRai
    GauravaRai , via OnePlus 6 , Mar 23, 2021 :
    What is "unexpected bug"? Define a bit in detail
  4. Sivanesan7234
    Froyo Mar 23, 2021
    Sivanesan7234 , via OnePlus 6 , Mar 23, 2021 :
    After updating 10.3.9, apps are crashing while using. Especially the browsing apps that uses Google service and Chrome. Please someone help me with this issue.
    D.Sai Suhail Baba and iamrj like this.
  5. U1551898310567
    Cupcake Mar 23, 2021
  6. G_Frederick_Seidl_wBQP , via OnePlus 6T , Mar 23, 2021 :
    Yesterday I got the new OxygenOS 10.3.9 for my OP 6T. Since that every app is crashing after a few seconds.....anyone experiencing the same?
    How can I fix this. Never had any issues before the update.
  7. AyazIsayev
    Eclair Mar 23, 2021
  8. D.Sai Suhail Baba and iamrj like this.
  9. Caoimhín
    OnePlus 9 Series Expert Community Expert Mar 23, 2021
  10. Sivanesan7234
    Froyo Mar 23, 2021
    Caoimhín and D.Sai Suhail Baba like this.
  11. Caoimhín
  12. Caoimhín likes this.
  13. ASMITSHARMA
    Gingerbread Mar 23, 2021
    ASMITSHARMA , via OnePlus 6T , Mar 23, 2021 :
    This is happening with me too!
  14. G1562203733970
  15. Caoimhín
    Caoimhín , via OnePlus 6T , Mar 23, 2021 :
    Enable/Disable Ram Boost and also Enable/Disable DC Dimming.
    Try different combinations of both and see which may improve your issue.
    Auristic, ItsRavi25 and ASMITSHARMA like this.
  16. Caoimhín
  17. ASMITSHARMA
    I've been trying to fix this by exact same method... sadly nothing happens
  18. G1562203733970
  19. Caoimhín
    If you haven't already tried it. Might be worth looking into backing up the phone and doing a full Erase All Data factory reset. Will refresh current OOS.
  20. ASMITSHARMA
    And I don't know this issue is with my device only but...if you enable DC dimming and your auto brightness is enabled than the brightness is less as compared to when DC dimming is disabled
