84
OxygenOS 10.3.9 for the OnePlus 6 and 6T
  1. iamrj
    Ice Cream Sandwich Apr 3, 2021
  2. rhyd1am , via OnePlus Community App , Apr 3, 2021 :
    Are you using a VPN?
    Also does it give your correct location if you open Google maps?
    There's a couple of things you could try here.
    Search for location in the settings, and click on "location services". Clear the storage and cache for that and check that you have the location permission enabled.
    In settings choose location, and make sure wi-fi scanning and Bluetooth scanning are both enabled.
    Also check that you have location enabled for all the apps that you need it turned on with.
    Open Google maps, tap on the blue dot showing your location (it at least where it thinks you are). At the bottom left you'll then see "calibrate compass". Follow the instructions under that option.
    ItsRavi25, Auristic, dashxdot and 2 others like this.
  3. iamrj
    iamrj , Apr 3, 2021 :
    Hi, Go to Playstore and install OnePlus Care
    Then click on Diagnose your device
    See if there is any hardware issues or check with services center. Hope this works.
    Ronesso17 and D.Sai Suhail Baba like this.
  4. mika90
    Froyo Apr 3, 2021
  5. adityaroy110
    Cupcake Apr 3, 2021
    adityaroy110 , via OnePlus 6T , Apr 3, 2021 :
    Thanks for instructions, I don't use vpn and I already tried clearing cache of location service not working
  6. Sanky8990
    Froyo Apr 3, 2021
    Sanky8990 , via OnePlus 6 , Apr 3, 2021 :
    After update, I'm having network issue like Internet band switching more often, also wifi automatically disconnect.
    I tried reset wifi and network settings but nothing changed.
  7. dashxdot
    Gingerbread Apr 3, 2021
    dashxdot , via OnePlus 6T , Apr 3, 2021 :
    Try this. Settings> apps and notifications> see all xx apps> three dots on the top right corner> reset app preferences> reset apps. Also, see if wifi and bluetooth scanning is enabled in the location section as mentioned in the above post.
    Caoimhín and rhyd1am like this.
  8. Dante69
    Froyo Apr 3, 2021
    Vikashlb likes this.
  9. iamrj
    I tried this nothing happens issues with Oxygen OS bugs
    D.Sai Suhail Baba likes this.
  10. Ronesso17
    Honeycomb Apr 3, 2021
    Ronesso17 , via OnePlus 6T , Apr 3, 2021 :
    It's a software problem even I am facing battery issues and my battery health is 86%. Not everyone has money to burn unlike you.
  11. iamrj
    Well preach buddy! 🤣
  12. Ronesso17
    Someone has to introduce these fanboys to the concepts of rational-thinking and common-sense, bhai.
  13. rakeshgergal
    Froyo Apr 3, 2021
  14. iamrj
    iamrj , via OnePlus 6 , Apr 3, 2021 :
    Dear @Abdul B.,
    Camera
    Improved the sharpness, noise and white balance of the rear camera
    Improved the white balance performance of the front camera
    Improved the zoom performance
    Improved the camera stability
  15. rhyd1am , via OnePlus Community App , Apr 3, 2021 :
    What version of YouTube are you on?
    Seems to be working fine on my 6T. I'm using the beta version 16.13.34
  16. rakeshgergal
    Froyo Apr 3, 2021
    D.Sai Suhail Baba and rhyd1am like this.
  17. rakeshgergal
    Froyo Apr 3, 2021
    rakeshgergal , via OnePlus 6T , Apr 3, 2021 :
    beta testing is full ...so can't update . i have tried clearing cache but still the same issue
  18. Yashodananda
    Cupcake Apr 3, 2021
    Yashodananda , via OnePlus 6 , Apr 3, 2021 :
    Please restart your phone.
    Try clearing cache partition.
    But restarting phone will do it.
    D.Sai Suhail Baba, iamrj and rhyd1am like this.
