98
OxygenOS 10.5.10 for the OnePlus Nord
  1. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 29, 2020
    Caomhin , via OnePlus 6T , Dec 29, 2020 :
    Cleaning the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully can sometimes fix the issue.
    Auristic and I1596998878417 like this.
  2. Caomhin
    With that many issues I would suggest a complete Factory reset.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    ⚠️Enable Erase Internal Storage⚠️
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    How to Backup Android Phone to Google Drive
    https://mashtips.com/android-backup-to-google-drive/
    Auristic likes this.
  3. Caomhin
    Maybe it's only added as an additional file update for those updating via OTA
  4. Fast_and_Curious , via OnePlus Nord Blue Marble , Dec 29, 2020 :
    It is only added on the Indian ROM. Not for EU.
    Nope. Its only for Indian ROM. Dont know the logic for this.
  5. Bio84Hazard
    Eclair Dec 29, 2020
    Bio84Hazard , via OnePlus Nord , Dec 29, 2020 :
    Ok, clear... [e]1f609[/e] Thanks
  6. Caomhin
    Well that clarifies that, probably in the first post top of the thread, missed it. 👍🏻
  7. Royalmaharana
    Donut Dec 30, 2020
    R1592668395904 likes this.
  8. NordVeera
    Donut Dec 30, 2020
    NordVeera , via OnePlus Nord , Dec 30, 2020 :
    Worst update ever,,, as a new user I thought we will get monthly updates based on community request... But I didn't see none of our requests are full filled..
    Atleast give OnePlus Dialer and Messages app instead of Google dialer
  9. paresh.panera
    Cupcake Dec 30, 2020
  10. varsha03
    varsha03 , via OnePlus Nord , Dec 30, 2020 :
    I dont want notification alert when i start to record calls ..it makes an alert to other person on the call also.. which makes me feel uncomfortable to record calls.. please try to change the inbuilt alert of the call recording
  11. Nilesh 007 , via OnePlus Nord Blue Marble , Dec 30, 2020 :
    Use it by yourself then you will get to know why i, wasted 30 k buks on this shit. Reseting the phone for a bunch of problems is not a solution, solution is the development team who makes this buggy phone. I used almost every oneplus phone i was a big BIG fan then this Nord came and all gone. CeO of oneplus also said that Nord phone was a Mistake
  12. PradeepPlus
    Honeycomb Dec 30, 2020
  13. PradeepPlus
    PradeepPlus , via OnePlus Nord , Dec 30, 2020 :
    THIS!! ..is the best joke I've ever heard.
    What would you expect from a OnePlus fanboy!? Hahahah
    Prashant2496 likes this.
  14. Fast_and_Curious , via OnePlus Nord Blue Marble , Dec 30, 2020 :
    As this phone was advertised to be using google communication suite, you wont get this for sure.
    This is upto google as it uses google communication suite. And its not a good practice to record anybody without notifying them.
    Caoimhín and Bio84Hazard like this.
  15. AgniTejas likes this.
  16. Q1597738168246
    Gingerbread Dec 30, 2020
    Q1597738168246 , via OnePlus Nord , Dec 30, 2020 :
    They forget you. They just fooled us on the name of flagship budget phone.
  17. Himanshu.Behera
    Jelly Bean Dec 30, 2020
