38
OxygenOS 10.5.10 [IN], 10.5.9 [EU] and 10.5.11 [NA] for the OnePlus 8
  1. Adrian1976 , via OnePlus 8 Pro Glacial Green , Aug 1, 2020 :
    I see you still haven't fixed the scrolling smootheness of YouTube, this is ridiculous really on a 2020 device, get it fixed, it scrolls like crap, is it so difficult to use 120hz for scrolling for a global app.
  2. C1508158874911
    Gingerbread Aug 1, 2020
    C1508158874911 , via OnePlus 8 , Aug 1, 2020 :
    Fingerprints do not work when I place the phone on a flat surface, but it works when I hold the phone in my hand on my ONEPLUS8.
    Do u anybody faced that issue?
  3. G_Suvankar_Ghosh
    Eclair Aug 1, 2020
    tallguy0187 and Himanshuchamoli like this.
  4. Himanshuchamoli
  5. C1508158874911
    Gingerbread Aug 2, 2020
    W1508491554407 likes this.
  6. G_Suvankar_Ghosh
    Eclair Aug 2, 2020
    G_Suvankar_Ghosh , via OnePlus 8 , Aug 2, 2020 :
    There are many problems like finger print issue, display issue, photo quality issue etc etc
  7. A1543216110703
    Donut Aug 2, 2020
    A1543216110703 , via OnePlus 8 , Aug 2, 2020 :
    OnePlus standard is going down soon they will lose all valuable customers. Display issue camera quality many more. OnePlus need to fix this problems soon.
  8. T1595127613810 , via OnePlus 8 Pro , Aug 2, 2020 :
    It's true bro iam one plus fan's
  9. Sherwindavid
    Cupcake Aug 2, 2020
    Sherwindavid , via OnePlus 8 , Aug 2, 2020 :
    Hello one plus already mentioned about a issue in camera quality and in slow motion
    and now facing battery optimization issue it's
    almost draining 15 percent in 30mins in my device kindly make sure and correct it in following update.
  10. Lakshay155
    Froyo Aug 2, 2020
    Lakshay155 , via OnePlus 8 , Aug 2, 2020 :
    I'm using also using Jio and haven't faced a single issue
  11. X1586860665574
    Cupcake Aug 2, 2020
  12. psurendersharma
    Eclair Aug 2, 2020
    Sherwindavid and W1508491554407 like this.
  13. A1543216110703
    Donut Aug 2, 2020
    Q1591071172930 likes this.
  14. HASHIR111
    Cupcake Aug 2, 2020
  15. Tee_Eee_Bee
    Honeycomb Aug 2, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Aug 2, 2020 :
    Check your settings to see if you have the camera hidden:
    Settings -> Display -> Advanced -> Front Camera Display Area
  16. Tee_Eee_Bee
    Older OnePlus phones with a slow charging speed have seen improvements by cleaning out the charging port, cable plugs and charging brick.
    Try using something like a toothpick and make sure there is no lint etc. in the ports.
  17. psurendersharma
    Eclair Aug 3, 2020
    psurendersharma , via OnePlus 8 , Aug 3, 2020 :
    Its s new phone . I purchased it just before a month .
    Sherwindavid likes this.
  18. Tee_Eee_Bee
    Honeycomb Aug 3, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Aug 3, 2020 :
    Still can't hurt to clean out the charging ports.
    Also, if you can, try another cable or charger to see if that makes a difference.
