38
OxygenOS 10.5.10 [IN], 10.5.9 [EU] and 10.5.11 [NA] for the OnePlus 8
  1. r_praveeenumar
    Cupcake Jul 19, 2020
  2. G1586880328998
    G1586880328998 , Jul 19, 2020 :
    After I applied the update, 5G is completely gone.
    Using Deutsche Telekom as provider, I had 5G 90% of the time when checking the phone, since the update I have not once seen 5G displayed.
    Yes, I have disabled the intelligent 5G thing.
    G1593455081536 likes this.
  3. Roger.T
    Ice Cream Sandwich Jul 19, 2020
  4. pkatole24
    Froyo Jul 19, 2020
  5. amanps
    Gingerbread Jul 19, 2020
  6. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 19, 2020 :
    Tried resetting the APN?
    jude Fernandez likes this.
  7. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 19, 2020 :
    Not sure what issue that it is referring to. I have reported an issue that prevented automatic start of the fan during Warp charging though. Fixing the problem included restarting the charger.
    Wonder if it is fixed.
    "The charging works perfectly. It's only the fan that does not start as it should.
    1. Disable bedtime mode
    2. Test. Works.
    3. Change time of bedtime mode. Test. Fans does not start as inteended. OK
    4. Change back time to the same time as before. Fans should start but does not.
    5. Disable bedtime mode. Fans should start but does not.
    6. Enable bedtime mode again. Still no fans.
    7. Try my second charger. It works. Repet the steps above. That fails too.
    8. Disconnect the chargers and plug them in again. Both works. " 😋
    Mike_Jiang and rHITkM like this.
  8. Martijn_Goossens
    Honeycomb Jul 19, 2020
  9. mangesh_singh
    Froyo Jul 19, 2020
  10. JelleZon
    Lollipop Jul 19, 2020
  11. Funk Wizard
    Lollipop Moderator Jul 19, 2020
  12. #33
    L1583759254487 likes this.
  13. #34
    Gatonye likes this.
  14. b.chetanmajge
  15. Soulsurfer919
  16. #37
  17. H1593772403132
    #38
  18. Alejandrofdez343
    Eclair Jul 19, 2020
    #39
    Sikunbehera25 likes this.
  19. Andy lone
    #40
