74
OxygenOS 10.5.11 [IN], 10.5.10 [EU] and 10.5.12 [NA] for the OnePlus 8
  1. I1598111241526
    Cupcake Sep 4, 2020
    I1598111241526 , via OnePlus 8 , Sep 4, 2020 :
    hi i really dont know about that. When i turned on my phone for the first time it stated that theres an updated, it updated to this software im using now. Maybe try and check for new updates on your settings?
  2. Interstellar Demon , via OnePlus 8 , Sep 4, 2020 :
    Hey Guys,
    hope you all doin fine.
    I Just received the 10.5.11 Update on my EU OP8.
    patchlevel ist still 08/2020 and patchnotes seem to be the same as the 10.5.10 Update before. Any ideas whats going in ?
    Cheers
  3. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 4, 2020 :
    Indian device?
    These are the changelogs though...
    Newest
    Changelog:
    System
    Fixed the overlapping character display issue with Ambient display
    Fixed known issues and improved system stability
    Updated Android Security Patch to 2020.08
    Camera
    Optimized shooting effect with front camera
    Previous
    Changelog:
    System
    Newly adapted OnePlus Buds, easier to take advantage of wireless connection
    Provided a variety of clock styles for you. You can customize on your own. (Go to Settings>Customization>Clock style)
    Optimize the touch experience in game mode to enhance the user experience
    Fixed the issue that the wireless charger base re-started automatically
    Fixed the ARCore failure
    Updated Android Security Patch to 2020.07
    Updated GMS package to 2020.05
    Improved system stability
    Network
    Improved the performance and stability of Wi-Fi transfers
    Improved connection stability of mobile network to improve user experience
    Shelf
    Newly added Red Cable Club membership card (IN only)
  4. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 4, 2020 :
    Different updates in different regions. "NA" have 12, India 11, EU 10. Same update but with slight regional differances.
  5. Interstellar Demon , via OnePlus 8 , Sep 4, 2020 :
    Here is the changelog
  6. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 4, 2020 :
    If you check about phone you see the firmware type and model.
    Might be an hotfix. Then the changelog may not always change.
  7. Interstellar Demon , via OnePlus 8 , Sep 4, 2020 :
    indeed looks Like a hotfix to me as well. Model is IN2013 btw
  8. Interstellar Demon likes this.
  9. I1598111241526
    Cupcake Sep 4, 2020
  10. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 4, 2020 :
    9 h since disconnect. Near 2.5h screen time. More than 75% left. If equally draining all the time you might get 10h SoT based on what I can see.
    You mean idle drain is high or screen drains too much? Powerful SoC, bigger and more power hungry display I guess...
    From what I see it's not necessarily bad.
    You might want to tweak settings and disable stuff you don't want or need... Several guides and tool tips.
    https://forum.xda-developers.com/showthread.php?t=1827676
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
  11. I1598111241526
    Cupcake Sep 4, 2020
    Screen time drains fast. Is it a battery problem?
  12. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 4, 2020 :
    Isn't it both brighter and bigger than previous device? Bigger screens bigger drain.
    2.5h and still 77% isn't very bad. Depends on used brightness manual/auto brightness adjustments and such
    I1598111241526 likes this.
  13. I1598111241526
    Cupcake Sep 4, 2020
    I see. Thanks. But many are complaining about the software update which made their phone's battery drain fast. The youtube reviews on battery drain test is i think not exactly the same for all
  14. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 4, 2020 :
    Exactly. Many things matter. Some get great battery. Some bad. Some wipe caches over and over and never charge fully and let a background optimize finish... Some don't wipe caches and charge nightly on regular basis or even all nights. Some install practically all the worse battery killers they can find. Some don't. Some activate this or that setting here and there. Some turn stuff off they don't need. Guess who gets best battery most of times [e]1f609[/e]
  15. I1598111241526
    Cupcake Sep 4, 2020
    Who? [e]1f628[/e] Thank u for the help brother. Hoping my phone would get better w the help of ur tips!! oh and also i activated my dark mode, accordingly it saves more battery [e]1f603[/e]
    Swejuggalo likes this.
  16. GaryWall
    Gingerbread Sep 4, 2020
    GaryWall , Sep 4, 2020 :
    Did you notice the file size for the update?
  17. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 4, 2020 :
    Out on Oxygen Updater. Only as full update so far.
    Hopefully we get some info about what this hotfix actually fixes soon or perhaps just note in the update posts already existing.
