73
OxygenOS 10.5.11 [IN], 10.5.10 [EU] and 10.5.12 [NA] for the OnePlus 8
  1. W1508491554407
    Gingerbread Sep 10, 2020
    W1508491554407 , via OnePlus 8 , Sep 10, 2020 :
    Earlier i downloaded once it had all Chinese apps only. So i though this one has all apps in English ?
  2. Tee_Eee_Bee
    Ice Cream Sandwich Sep 10, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Sep 10, 2020 :
    Yes, the apps are in english.
  3. W1508491554407
    Thanks for replying 🙂. If a stable version of this comes will I het notified ? As i will be on beta, or i have to download stable separately ? If i mive to this will my current data be lost ?
  4. Tee_Eee_Bee
    You won't be notified of stable updates in beta, but you can still download and update manually.
    You shouldn't lose any data moving to open beta 1, but it's always good practice to back everything up just in case.
    With my OP 6T, I could switch between stable and beta without losing data so long as the version I was installing had a newer build date than the current version.
    Caoimhín and W1508491554407 like this.
  5. andrewd71
  6. W1508491554407
  7. pkatole24
    Froyo Sep 10, 2020
  8. GaryWall
    GaryWall , Sep 10, 2020 :
    10.5.12.IN21BA came as a 128 mb incremental file (as I had 10.5.11 also from Oxygen Updater) and the change log is the same as .10 with the addition of "Improved performance with European operators" as was the same with .11.
  9. andrewd71
    andrewd71 , Sep 10, 2020 :
    As above.
  10. Amyth007
    Eclair Sep 10, 2020
    Amyth007 , via OnePlus 8 , Sep 10, 2020 :
    Nothing's good with this phone, I woke up the screen and the fingerprint scanner was missing from the screen though after locking and unlocking again it came back.
    I am facing soo many issues with this device ,the touch wake option doesn't work sometimes.
    I don't know whether it's a hardware or software issue
    Even the touch response is not crisp.
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 12, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 12, 2020 :
    Android has since a long time demanded pin after a certain amount of time of only using fingerprint. I'm not sure of the exact time frame of this though (3 days for example - meaning no reboots, and only using fingerprint since first unlock).
    The same after a reboot (but then it says that is has rebooted and therefor needs pin/password).
    When you have reached that full time when pin is automatically asked for it says something like "for added security" for the reason of why it asks for pin/password.
  12. J1599196092390
    Eclair Sep 15, 2020
  13. J1600279358184
    Cupcake Sep 16, 2020
    J1600279358184 , Sep 16, 2020 :
    OnePlus 6 t user doesn't have any value .? only new customer are having value for OnePlus industry ? why no update of Andriod 11 Oxygen for 6t
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 16, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    6/6t are the ones that gets 11 the last. When 10 came 5/5t was the last devices that got it.
    Not even 8 series got a stable release yet. And no beta for 7/7t yet... The time comes to your device too in the correct normal order as new versions usually get rolled out on Oneplus.
    J1600279358184 likes this.
  15. [email protected]
    Cupcake Sep 17, 2020
  16. GaryWall
    Gingerbread Sep 17, 2020
  17. Himanshuchamoli
    Himanshuchamoli , via OnePlus 8 , Sep 17, 2020 :
    Go switch to Apple
  18. ArtuCer
    Gingerbread Sep 18, 2020
    ArtuCer , Sep 18, 2020 :
    Does Apple already have Android 11?
    W1508491554407 likes this.
