73
OxygenOS 10.5.11 [IN], 10.5.10 [EU] and 10.5.12 [NA] for the OnePlus 8
  1. guhanjg264
    Cupcake Sep 26, 2020
    A1509557061431 likes this.
  2. @Mani124
    Donut Sep 26, 2020
  3. @Mani124
    Donut Sep 26, 2020
    @Mani124 , via OnePlus 8 , Sep 26, 2020 :
    Not installed sir
  4. guhanjg264
  5. anwar.kadiwala
    Eclair Sep 27, 2020
  6. nsaismruti
    Eclair Sep 30, 2020
  7. Himanshuchamoli
    Gingerbread Oct 1, 2020
    F1597919646648 likes this.
  8. Himanshuchamoli
  9. cyberman_5145
    Honeycomb Oct 2, 2020
    cyberman_5145 , via OnePlus 8 , Oct 2, 2020 :
    facing issue with ringing volume which fades out immediately when I pick / raise the phone in my hand.
    has anyone faced this issue on OnePlus 8 Indian variant? pls suggest a workaround if you were able to get this right. thanks
  10. Deactivated User
    Oct 2, 2020
  11. cyberman_5145
    cyberman_5145 , via OnePlus 6 , Oct 2, 2020 :
    you are a star man. Thanks for the help here. it worked. Cheers.!!
  12. ijus_amazing
    Gingerbread Oct 2, 2020
    ijus_amazing , Oct 2, 2020 :
    Unrelated question but if I buy op8 pro from North America site would it be dual sim? I was seeing some posts that dual sim function not working?
  13. Swappyy
    Eclair Oct 2, 2020
    Swappyy , via OnePlus 8 , Oct 2, 2020 :
    issue with headphone's / earphone's mic, listeners listen my voice in low volume even my all volume setting is in high. when i play online gaming then it works very fine but in calling function it dont.
    pls advice if anybody knows settings.
  14. GaryWall
    GaryWall , Oct 2, 2020 :
    You cannot control the volume of your outgoing voice, that is for the receiver to do. If the sound is low for all receivers alike, then there might be something wrong with your microphone. Try the built-in and/or other headsets to pinpoint the error.
  15. Himanshuchamoli
    Gingerbread Oct 4, 2020
  16. Daxzy
    Froyo Oct 4, 2020
    Daxzy , Oct 4, 2020 :
    Still no one-handed mode? How many more people need to ask for this for you to actually implement it? WHAT THE ****!?
  17. Daxzy
    Froyo Oct 4, 2020
    Go and do a rollback
  18. GaryWall
    GaryWall , Oct 4, 2020 :
    Have you even been in contact with the support? This is a user form so you can stop shouting and save it for the messages you send to actual OP support people. Are you OK with this?
  19. Swappyy
    Eclair Oct 5, 2020
    Swappyy , via OnePlus 8 , Oct 5, 2020 :
    i have tested with other headphones, seems like software issue. sometimes get issue oland sometimes not
