47
OxygenOS 10.5.12 and 10.5.11 [EU] for the OnePlus 8 Pro
  1. T1595127613810
    Donut Jul 31, 2020 at 8:30 PM
  2. jahnz6
    Eclair Jul 31, 2020 at 9:10 PM
    jahnz6 , via OnePlus 8 Pro , Jul 31, 2020 at 9:10 PM :
    Hi,
    Works fine so far, wifi stability still isn't the best and some issues on reconnet with bluetooth when in the car. Also pls fix the issue that chrome still freezes.
    Keep going 🤙🏼
  3. Yannis Neris
    Ice Cream Sandwich Aug 1, 2020 at 7:39 AM
    Yannis Neris , Aug 1, 2020 at 7:39 AM :
    I personally don't Screenshot_20200801-083905.jpg have any issue on Chrome ( forced on 120hz)
  4. Soulsurfer919
    Honeycomb Aug 1, 2020 at 7:59 AM
    Soulsurfer919 , via OnePlus 8 Pro Glacial Green , Aug 1, 2020 at 7:59 AM :
    Oxygen os need more optimization on various departments. After this update daily SOT has gone down by 1hr compared to previous few updates. And having Mobile network data dropping after idle for a while. And chrome having glitches and freezes that really spoil the user experience so moved to New firefox this week and no issues so far even opening links in third party apps are also now a breeze. Hoping OnePlus or Google can fix the chrome issues by Android 11 release as I have noticed thus issues after android 10 update for chrome it really hinders with the user experience.
    I am hoping for a solid update from OnePlus incoming soon!
    On the other postive note after using the device for more than a month now no display issues and it's a joy to the eyes. Hoping OnePlus can iron out the oxygen OS soon for a much better experience.
    Wondering if development has moved to android 11! Less intrested in fixing Android 10!
    Alejandrofdez343 and Tanmoy1285 like this.
  5. Adj0
    Cupcake Aug 1, 2020 at 11:24 AM
  6. BlackJet
    Cupcake Aug 1, 2020 at 11:32 AM
  7. Swejuggalo
    Lollipop Aug 1, 2020 at 12:33 PM
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 1, 2020 at 12:33 PM :
    It's "optimized" and when you try it it clearly says what you should do to get the effect.
    If you refer to the side effects on how it worked before. They are gone due to the x-ray claims and stuff...
  8. Adj0
    Cupcake Aug 1, 2020 at 12:34 PM
    Adj0 , via OnePlus 8 Pro , Aug 1, 2020 at 12:34 PM :
    The filter often disappear for me...
    I don't know if it's normal ?
  9. Swejuggalo
    Lollipop Aug 1, 2020 at 12:35 PM
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 1, 2020 at 12:35 PM :
    No. But several are stuck of some reason. Happen to have used Oneplus Switch to transfer everything from an older device?
    You could always use the homepage. Support, Software Updates.
    BlackJet likes this.
  10. Swejuggalo
    Lollipop Aug 1, 2020 at 12:40 PM
  11. Adj0
    Cupcake Aug 1, 2020 at 12:43 PM
    Adj0 , via OnePlus 8 Pro , Aug 1, 2020 at 12:43 PM :
    I don't think so but I can't be sure...
    I'll see if it happens again in the future
    Thanks for your answers !
  12. 47_tejz
    Cupcake Aug 1, 2020 at 3:58 PM
    GarysOnePlus and gourabcena like this.
  13. GarysOnePlus
    Eclair Aug 1, 2020 at 6:57 PM
    GarysOnePlus , via OnePlus 8 Pro , Aug 1, 2020 at 6:57 PM :
    Indeed. The worst part about this is that I have gcam installed from xda and just different algorithm can take way better and sharper selfies using exactly the same hardware. 🤯
    gourabcena likes this.
  14. adarshgopinathan
    Donut Aug 1, 2020 at 8:15 PM
  15. Swejuggalo
    Lollipop Aug 1, 2020 at 8:34 PM
    adarshgopinathan likes this.
  16. shubham8166408
    Froyo Aug 1, 2020 at 9:54 PM
    shubham8166408 , via OnePlus 8 Pro , Aug 1, 2020 at 9:54 PM :
    I think u are lucky to not face a display issue.. I got a replacement but still a display issue..Very disappointing for me..
    Can u send me screen shot of ur display on brightness around 35_40 percent for comparison.
  17. Arjun Choudhry
    Honeycomb Aug 1, 2020 at 9:57 PM
    Arjun Choudhry , Aug 1, 2020 at 9:57 PM :
    The screenshot does not show the display issues. In case you want to check the display, you need a photo clicked of the display
  18. gorantallica
    Cupcake Aug 1, 2020 at 10:22 PM
    O1588995805326 likes this.
  19. Swejuggalo
    Lollipop Aug 1, 2020 at 10:30 PM
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 1, 2020 at 10:30 PM :
    Not everything is a OS issue though if Chrome fails. Even Pixel users have issues with it. However.... If 6/6t gets a fix on the OS side... We should too.
    Does not mean Chrome will suddenly stop having problems... Just that one issue has been dealt with. Oneplus can't fix Chrome devs issues.
    gorantallica likes this.
  20. Tee_Eee_Bee
    Honeycomb Aug 2, 2020 at 12:06 AM
