54
OxygenOS 10.5.12 and 10.5.11 [EU] for the OnePlus 8 Pro
  1. Alijabbar01
    Donut Aug 9, 2020
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 9, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 9, 2020 :
    Try reporting this via the feedback tool. It should start a recording that you can run for a while and hopefully replicate the issue. When replicated you can press stop and send it in
  3. PGopalakrishnan
    Froyo Aug 9, 2020
  4. Montu001
    Gingerbread Aug 9, 2020
  5. Montu001
  6. BMG1900
    BMG1900 , via OnePlus 6 , Aug 9, 2020 :
    read the damn explanation that will answer your question
    fidus62 and Montu001 like this.
  7. Montu001
  8. ChristianHeilos
    Honeycomb Aug 9, 2020
    ChristianHeilos , Aug 9, 2020 :
    That is correct, so if you are not confident how you can unbrick your phone I would avoid it....
  9. GarysOnePlus
    Froyo Aug 10, 2020
    GarysOnePlus , via OnePlus 8 Pro , Aug 10, 2020 :
    Yes, Sweden, US - Verizon, UAE - Virgin Mobile. Report your issue and they will send you instruction to collect the log.
  10. O1564502743470
    Eclair Aug 10, 2020
    O1564502743470 , via OnePlus 8 Pro , Aug 10, 2020 :
    hello,I am facing random reboots at various intervals on my oneplus 8 pro,please what could be the cause of this and what is the solution?I am fed up,as my phone is unusable.
  11. gubro
    KitKat Aug 10, 2020
    gubro , Aug 10, 2020 :
    The solution is to give them feedback. Read the first post of this thread.
  12. K1593509862611
    Cupcake Aug 10, 2020
  13. K1593509862611
    K1593509862611 , via OnePlus 8 Pro , Aug 10, 2020 :
    just check the version of oxygen os.
  14. J0har
    marfz likes this.
  15. prodigy3k
    prodigy3k , via OnePlus 8 Pro , Aug 10, 2020 :
    I'm still on 10.5.8 with my OnePlus 8 Pro and the system tells me there's no update available. Can you tell me if I need to do anything to make it check for a new version? I've got the European device, located in Germany. Current version: 10.5.8.IN11BA
  16. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 10, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 10, 2020 :
    Did you by any chance do a full backup from your old phone? Is it an IN2023?
    You could always download it and upgrade manually.
    OnePlus homepage, support, Software upgrade.
  17. ChristianHeilos
    Honeycomb Aug 10, 2020
    ChristianHeilos , Aug 10, 2020 :
    Or use OxygenUpdater, making sure you set the correct phone version in settings
  18. anilkigal
    Ice Cream Sandwich Aug 10, 2020
  19. anilkigal
