54
OxygenOS 10.5.12 and 10.5.11 [EU] for the OnePlus 8 Pro
  1. Tanshid_45
    Eclair Aug 10, 2020
    Tanshid_45 , via OnePlus 8 , Aug 10, 2020 :
    Auto brightness is not working properly and video brightness really sucks on the device....I don't know if it is caused of the update, if so, please fix it
  2. Tee_Eee_Bee
    Jelly Bean Aug 10, 2020
  3. Montu001
    Gingerbread Aug 11, 2020
    Montu001 , via OnePlus 8 Pro , Aug 11, 2020 :
    When Will be network issue resolved..feeling like looted ...
    even there is no option to change lte ...only 2g 3g 4g...in jio sim...other mobiles are doing great in network in same location....
    Low data speed
    Call drop
    Mobile on but other party says ur mobile off....(जिसकी वजह से कल बॉस से अच्छी खासी डाट पड़ी ) बोले mi ले ले 5000 में नेटवर्क तो आएगा तेरा।
    क्या किसीको उम्मीद है नेटवर्क issue कब तक resolve हो सकता है।
  4. Uchiha Hunter
    Eclair Aug 11, 2020
  5. Montu001
  6. H1595405913404
    Cupcake Aug 11, 2020
    H1595405913404 , via OnePlus 8 , Aug 11, 2020 :
    Hi Oneplus,
    sometime paytm app not working or showing white screen while i open the open and there is one more issue chrome sometimes freeze the screen while first instance open the app i can't even scroll up down or not even able to type.
    i am using one plus 8(8+128).
    thanks
    Montu001 likes this.
  7. gubro
    KitKat Aug 11, 2020
    gubro , Aug 11, 2020 :
    Nobody here is from OnePlus.
    Oh and by the way this is a OnePlus 8 Pro thread.
    Read the opening post.
  8. Tee_Eee_Bee
    Jelly Bean Aug 11, 2020
    Tee_Eee_Bee , Aug 11, 2020 :
    LTE is considered to be 4G:
    https://www.digitaltrends.com/mobile/4g-vs-lte/
    If you haven't already, try resetting your network adapters via Settings > System > Reset Options > Reset WiFi, mobile & bluetooth and see if it makes a difference.
    This will mean you have to re-connect to any WiFi networks you would normally connect to.
  9. Montu001
    sir i already have don these things..even installed software build from one plus site again..
  10. Shubh2410
  11. Shubh2410
  12. Shubh2410
  13. V1596871884636
  14. anilkigal
    Ice Cream Sandwich Aug 11, 2020
  15. brmbjn
  16. Shubh2410
  17. gubro
    KitKat Aug 11, 2020
    Improve your reading skills. This is not support.
    SteveCP likes this.
  18. Montu001
    then what the hell is this...what u mean by improve your reading skill...first u improve ur way of talking
  19. gubro
    KitKat Aug 11, 2020
    gubro , via OnePlus 8 Pro , Aug 11, 2020 :
    Please refrain from swearing.
    If you had improved your reading skills, you would've already figured out, that you should follow the instructions in the first post.
  20. Montu001
    yaar simpe si bata hai..aap jyada knowledge wale honge...wo bechara nahi janta hoga..isiliye kah diya...
