27
OxygenOS 10.5.13 and 10.5.12 [EU] for the OnePlus 8 Pro
  1. nazreenyusof88
    Cupcake Sep 9, 2020
    nazreenyusof88 , via OnePlus 8 Pro , Sep 9, 2020 :
    I have problem with this update , when I'm typing message , the word I'm typing is delayed around 0.2 second , is this normal ? I'm new with Android and scare to use beta 😅
  2. ChaitanOneplus , via OnePlus 7 Pro , Sep 9, 2020 :
    We have to tell you that , our development team is working on this issue . So you just have to take a little patience & wait till the next update arrives .
  3. Last edited by a moderator: Sep 10, 2020
  4. ChaitanOneplus , via OnePlus 7 Pro , Sep 10, 2020 :
    I recommend you to wait for the OTA which will be pushed to you ➕
  5. ChaitanOneplus , via OnePlus 7 Pro , Sep 10, 2020 :
    The update can be full of bugs , the company can suspend it , it may affect your $749 device ......
    OTA means they brought it up to you accordingly..
    Have patience broski...
  6. ChaitanOneplus , via OnePlus 7 Pro , Sep 10, 2020 :
    Well I have seen UPADTE issues in XIAOMI phones , not the Oneplus ....
    But it's better to be aware coz u don't wanna poke a tiger with a stick in your hand with no further security [e]1f602[/e]
  7. RedVision81 , via OnePlus 8 Pro Glacial Green , Sep 10, 2020 :
    The only difference IMHO is you can download it immediately and you don't have to wait till you are the next on the staged rollout. The source (one plus servers) is the same.
  8. ChaitanOneplus , via OnePlus 7 Pro , Sep 10, 2020 :
    YUPP it's that way too .....
    I have experienced , so I tried to share that with you ...
    Since iam happy with my 1+7 PRO coz they have fixed a lot of issues & it have improved a lot since launch [e]2764[/e]️
  9. Edomer
    Cupcake Sep 10, 2020
    Edomer , via OnePlus 8 Pro , Sep 10, 2020 :
    I have the same problem on 10.5.13.IN11BA with two Telekom HU simcards.
  10. Jamal_B
    Jamal_B , Sep 10, 2020 :
    I never had any problems with network connection. Congstar, Germany is my provider.
    basspass likes this.
  11. Ajin_Grace_Thomas
    Eclair Sep 10, 2020
  12. M1584489685542
    Cupcake Sep 11, 2020
    M1584489685542 , via OnePlus 8 Pro , Sep 11, 2020 :
    selfie remaining the worst camera on mobile phone ever but they creates a very big problem, destroy the battery. before in 10 hours without using (when I am sleeping) the battery drop 7%, now in 6 hours drops 15%.
    I put settings on 60hz and fhd because it is not possible to stay on the phone all day with simple use.
  13. RedVision81 , via OnePlus 8 Pro Glacial Green , Sep 11, 2020 :
    No problems here, battery improved for me. Currently about 6 hours SOT with full resolution and 120hz
  14. dengg
    dengg , Sep 11, 2020 :
    Finally, I got an OTA update 😉 10.5.14
    IR camera can't be used to see "through" certain objects but the stylistic effect is better in my opinion because they are using the main camera now.
    I would like to have both options though
  15. D1590011581875
  16. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 11, 2020 :
    Probably on the way. It's never rolling out to everyone at once. No use in sending out 10.5.13, cancel it and then rollout 10.5.14 for all EU users before they have confirmed it to be good enough for everyone. Both are hotfixes with carrier specific stuff added apperently.
  17. Ramchi
    Donut Sep 12, 2020
  18. ChaitanOneplus , via OnePlus 7 Pro , Sep 13, 2020 :
    Don't use any third party beauty cams , once reset your device (TAKE A BACKUP)
    Ramchi likes this.
  19. Ramchi
    Donut Sep 13, 2020
    Ramchi , via OnePlus 8 Pro , Sep 13, 2020 :
    I use stock OnePlus 8 Pro camera only. I suspect the tempered glass could be the reason? Not sure
