31
OxygenOS 10.5.13 and 10.5.12 [EU] for the OnePlus 8 Pro
  1. gicuta77
    Cupcake Oct 15, 2020 at 2:34 PM
  2. Arvind Ramawat
    Cupcake Oct 16, 2020 at 4:51 AM
  3. rachit_asia
    Gingerbread Oct 16, 2020 at 3:55 PM
    rachit_asia , via OnePlus 8 Pro Glacial Green , Oct 16, 2020 at 3:55 PM :
    Which SIM? It's happening with OP 8 Pro as many users reported, myself included. No fix for this major issue by OnePlus! Pathetic service....
  4. B1596484446828
    Cupcake Oct 16, 2020 at 11:07 PM
  5. ajchem
    Cupcake Oct 19, 2020 at 10:46 AM
    ajchem , Oct 19, 2020 at 10:46 AM :
    Version 11.IN11BA (as in previous version 10.5.13.IN11BA) I'm still having trouble with NFC, problems using Google Pay on POS terminals in Poland - NFC reading issue. 2 months after reporting this issue, it has not been eliminated !!!
  6. Swejuggalo
    Lollipop Oct 19, 2020 at 11:03 AM
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 19, 2020 at 11:03 AM :
    Google Pay worked for me a period on beta 2...then Google Pay was updated and stopped working again. In that case I would not call it a Oneplus issue.
    I've reset it but haven't tested yet.
    Don't know the problem in your case though.
  7. FlugzeugSK
    Gingerbread Oct 19, 2020 at 11:12 AM
    FlugzeugSK , Oct 19, 2020 at 11:12 AM :
    same happened to me on Google Play Services Beta, solved by manual installing other version of GMS
    GuilR and Swejuggalo like this.
  8. Swejuggalo
    Lollipop Oct 19, 2020 at 11:29 AM
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 19, 2020 at 11:29 AM :
    Ah. Not a Oneplus issue then in that case.
    Haven't tried any other apps that uses NFC. Other apps that uses Play Services may fail too. So the users that relies on it might need to test different Play Services.
    What version number?
  9. ajchem
    Cupcake Oct 19, 2020 at 11:30 AM
    ajchem , Oct 19, 2020 at 11:30 AM :
    Maybe, but NFC is not working for me from September when I bought OP8Pro (rom 10.5.12) independently from Google Pay version. At the same time it works on my old one OP3 (with Lineageos17.1)
  10. FlugzeugSK
    Gingerbread Oct 19, 2020 at 11:31 AM
    FlugzeugSK , Oct 19, 2020 at 11:31 AM :
    it was on DP2, since OpenBeta it is all working.
    Swejuggalo likes this.
  11. FlugzeugSK
    Gingerbread Oct 19, 2020 at 11:32 AM
    FlugzeugSK , Oct 19, 2020 at 11:32 AM :
    maybe NFC is broken at your phone and it is a hardware issue ?
  12. ajchem
    Cupcake Oct 19, 2020 at 1:30 PM
    ajchem , Oct 19, 2020 at 1:30 PM :
    Probably not, nfc tags reads correctly. On the POS reader it reacts with a blue circle and an error or a red exclamation point (insert a card / card not supported on the POS terminal)
  13. ajchem
    Cupcake Oct 19, 2020 at 1:37 PM
    ajchem , Oct 19, 2020 at 1:37 PM :
    20.36.15
  14. FlugzeugSK
    Gingerbread Oct 19, 2020 at 1:38 PM
    FlugzeugSK , via OnePlus 8 Pro Ultramarine Blue , Oct 19, 2020 at 1:38 PM :
    is your phone correctly enrolled into GooglePay?
    you should be able to see something like this:
  15. ajchem
    Cupcake Oct 19, 2020 at 1:41 PM
    ajchem , Oct 19, 2020 at 1:41 PM :
    Yes, all marked - looks OK in the app, 2 different Polish and British credit cards attached
  16. FlugzeugSK
    Gingerbread Oct 19, 2020 at 1:43 PM
    FlugzeugSK , Oct 19, 2020 at 1:43 PM :
    did you try to contact GooglePay Support to check if they see any issue ?
  17. ajchem
    Cupcake Oct 19, 2020 at 1:54 PM
    ajchem , Oct 19, 2020 at 1:54 PM :
    not, yet. I only. I only sent error reports generated by google pay app, I also sent logs to the Oneplus support (according to the instructions from @MDMujtaba999) but I didn't get any answer
  18. Swejuggalo
    Lollipop Oct 19, 2020 at 3:09 PM
  19. FlugzeugSK
    Gingerbread Oct 19, 2020 at 3:28 PM
    FlugzeugSK , Oct 19, 2020 at 3:28 PM :
    i have also working GPay on 20.39.15
  20. Swejuggalo
    Lollipop Oct 19, 2020 at 3:47 PM
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 19, 2020 at 3:47 PM :
    The picture says 36 not 39 😉
    But anyway since it does not work for the other user on 36 but does for you the problem in that cases can't be the Play Services version. But might be in mine. Don't have access to try it more today. But I try a to reset a few thing and set it up again and try again tomorrow.
