32
OxygenOS 10.5.13 and 10.5.12 [EU] for the OnePlus 8 Pro
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 16, 2020
  2. SteveCP
    Jelly Bean Aug 17, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Aug 17, 2020 :
    Also that date doesn't exist [e]1f61c[/e]
    Swejuggalo likes this.
  3. Sinnaz0709
    Ice Cream Sandwich Aug 17, 2020
  4. Techi1409
    Gingerbread Aug 17, 2020
    Techi1409 , Aug 17, 2020 :
    Still "OPEN BETA" comes most likely on the 8th September and you can now try out the Developer Preview 3 of Android 11/OOS11
  5. ArjunAakko likes this.
  6. sandippe
    Donut Aug 17, 2020
  7. SteveCP
    It can take weeks before the update reaches everyone, by using Oxygen Updater you will receive it normally same day it is released.
  8. Yannis Neris
    Yannis Neris , Aug 17, 2020 :
    Youtube vanched running smoothly
    Q1511348354098 and Adrian1976 like this.
  9. Chandan Bharadwaj HN , via OnePlus 8 Pro , Aug 17, 2020 :
    oh ok. I have just a question on Oxygen updater. Is that application safe? what I mean is, After updating using Oxygen updater, will I get further updates to my phone via OTA?
  10. Praveen Ayanar likes this.
  11. SteveCP
    Perfectly safe have used it since I bought my 7 pro and never had an issue
  12. NikhilPandey94 , via OnePlus 8 Pro , Aug 17, 2020 :
    Why the front camera is so bad in video calls. It's just so blur in dark or dim light. Anyone facing the same? 2nd concern the mobile data connection is worst indoor even when the 10k phone gives great speed in same place... Data Speed fluctuate very quickly in OP 8 Pro...Why?
    AdvJaydeep likes this.
  13. ronakbarman
    ronakbarman , via OnePlus 8 Pro , Aug 17, 2020 :
    Front camera is fixed in this update bro, if it didn't for you, do a cache wipe, and if that doesn't helps, do a factory reset, I had to factory reset anyways since I rolled back from dp3 to Android 10
  14. Chandan Bharadwaj HN , via OnePlus 8 Pro , Aug 17, 2020 :
    Thanks, I will wait for another 2 days. If I didn't get the update, I will go with Oxygen updater and download that incremental update.
    SteveCP likes this.
  15. rachit_asia
    rachit_asia , Aug 17, 2020 :
    Seems some positive news regarding front camera. Are the images sharper now?
  16. sandippe
    Donut Aug 17, 2020
    sandippe , via OnePlus 8 Pro , Aug 17, 2020 :
    Yes it is much much better now, but there's still room for improvement. For low lit environment it still smooths out images at certain angles but not as agressive as before!
    Will do an extensive test and update on this!
    rachit_asia likes this.
  17. rachit_asia
    Bro, I have also experienced the same even on 4G+ Jio Network the speeds are way less like 3-4 Mbps.
    Even a mid-range phone at the same place has more data speeds. Why, Oneplus, why???
    thetruthofOp8 likes this.
  18. Goku_SuperSaiyan
    Goku_SuperSaiyan , via OnePlus 8 Pro , Aug 17, 2020 :
    provided in the starting of the page 1 !
    read carefully and follow
  19. mbruurs
    Donut Aug 17, 2020
    mbruurs , via OnePlus 8 Pro , Aug 17, 2020 :
    I received the update but the keyboard is reacting very strange after this. It puts strange characters while typing. Before the update this was not the case.
