22
OxygenOS 10.5.7 and 10.5.6 (EU) for the OnePlus 8
  1. cruzAD
    Gingerbread Jun 1, 2020
    cruzAD , via OnePlus 8 , Jun 1, 2020 :
    All AMOLED uses PWM technology?
    #81
  2. Swejuggalo
    Lollipop Jun 1, 2020
    #82
    cruzAD likes this.
  3. bedpapa
    Cupcake Jun 2, 2020
    #83
  4. #84
  5. E.roc
    Cupcake Jun 4, 2020
    E.roc , Jun 4, 2020 :
    I guess you doing something wrong the last update are from May (this device even exist at Oct 2019)
    See attached picture (Mai is german for May)
    Cheers!
    #85
  6. Koustubh_Shrivastava , via OnePlus 8 , Jun 4, 2020 :
    I know. but I didn't did anything. I just Purchased the One Plus 8 phone last week and got the update as October 2019 by default.
    #86
    Swejuggalo likes this.
  7. Swejuggalo
    Lollipop Jun 4, 2020
    Swejuggalo , Jun 4, 2020 :
    This is a common issue apperently. Even seen Pixels that actually upgraded Google Play System Update and the date said it was downgraded. Simply a incorrect date of some reason
    #87
  8. Koustubh_Shrivastava , via OnePlus 8 , Jun 4, 2020 :
    Or there is a possibility that the date is correct and it has not been updated. It might be due to some technical reasons. but is there anything that I could do to escalate this to the higher authority.
    #88
  9. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro , Jun 4, 2020 :
    Should fix itself next security update. If there is something possible to do right now... Don't really think so. Manually check for updates until it's updated again. It's some type of rollout method by Google. Does not come to all at once.
    You can always report this via the feedback tool.
    Maybe discuss with Google too since this issue is not exclusive for Oneplus.
    https://support.google.com/?hl=en
    #89
    Koustubh_Shrivastava likes this.
  10. Hamize
    Cupcake Jun 4, 2020
    #90
  11. E.roc
    Cupcake Jun 4, 2020
    ... and if you touch at the "Google Play System Update" to update manually? You tried?
    #91
  12. Koustubh_Shrivastava , via OnePlus 8 , Jun 4, 2020 :
    I tried everything. manually as well. few hours back I got an update too and after the update as well there is no change.
    #92
  13. Daniel_A_85
    Cupcake Jun 4, 2020
    Daniel_A_85 , via OnePlus 8 , Jun 4, 2020 :
    I noticed two bugs till now.
    1. some times when i am using chrom browser the display is freezing and not responding to touches for some period.
    2. the phone goes to silent mode by itself. the bar of ring is down. this is definitely not the slider.
    Is anybody els encounter these bugs?
    #93
  14. E.roc
    Cupcake Jun 4, 2020
    Weird
    I don't think oneplus can help you.
    Try to clear the cache over recovery, this doesn't help try a app reset (maybe a factory reset).
    I hope this can solve your problem
    #94
  15. G_jimmy_ng_YUSe
    Cupcake Jun 4, 2020
    G_jimmy_ng_YUSe , Jun 4, 2020 :
    #95
  16. G_jimmy_ng_YUSe
    Cupcake Jun 4, 2020
    #96
  17. garygates_21
    Eclair Jun 4, 2020
    garygates_21 , via OnePlus 8 , Jun 4, 2020 :
    Does anyone know if it's correct, that another update is around the corner? According to XDA there is a new update for both phones with may security patch, can anyone confirm?
    #97
  18. E.roc
    Cupcake Jun 4, 2020
    #98
  19. garygates_21
    Eclair Jun 4, 2020
  20. Tomj44
    Cupcake Jun 4, 2020
