107
OxygenOS 10.5.8 for the OnePlus 8 Pro
  1. J1589628039034
    Cupcake Jun 2, 2020
    J1589628039034 , via OnePlus 8 Pro , Jun 2, 2020 :
    To OnePlus, please decrease the vertical spacing between app icons on the 8 pro. it's a large screen vertically and the 5*5 icon tray in the usable area of the home screen has too much gap, as does the 5*6 in the app drawer.
    Or if not by default at least give an option in the home settings please.
    Please like if you agree.
    Thank you
  2. bkrickles
    Eclair Jun 2, 2020
    bkrickles , Jun 2, 2020 :
    It's one of the reasons I use Nova Launcher. I like my icons smaller and closer together.
  3. RRM300
    Eclair Jun 3, 2020
    RRM300 , Jun 3, 2020 :
    Is there a way to manually update to 10.8 or 10.9 oneplus 8 pro ?
    I don’t care much for the x ray cam
  4. jd2016
    Gingerbread Jun 3, 2020
    jd2016 , Jun 3, 2020 :
    if you put the phone in a toilet and let the whole family take a dump it will update to 10.9 or 10.8 shortly afterwards . that's the only way people have managed to get it to update as OnePlus don't care and aren't doing anything to fix issues and update the phones firmware .
    Huigiebaby likes this.
  5. S1591141085496
    Cupcake Jun 3, 2020
    S1591141085496 , via OnePlus 8 Pro , Jun 3, 2020 :
    Touchscreen Multitouch / Sensitivity issue.
    I have just switched from OP7pro to OP8pro and have 2 issues (this firmware) - I wonder if they indicate a hardware issue?
    Touch sensitivity is much lower e.g. keyboard and swipes and there seem to be false touches if try to type fast (the swipe line appears for no reason). screen protector off.
    There are a max of 3 Multitouch points (screenshot gesture switched off).
    Appreciate opinions?
  6. melvin.batista , via OnePlus 8 Pro , Jun 3, 2020 :
    I have exactly the same problem, but in my opinion it will not be solved because no one from the company mentions this problem
  7. JohnzyFitzgerald
    Froyo Jun 3, 2020
    JohnzyFitzgerald , Jun 3, 2020 :
    Please stop. You're only embarrassing yourself.
  8. Sinnaz0709
    Ice Cream Sandwich Jun 3, 2020
    Sinnaz0709 , via OnePlus 8 Pro Glacial Green , Jun 3, 2020 :
    if you're willing to risk it I'm sure there's a link to the manual download. Now note 10.5.9 just disabled the camera only in error... and if you're in NA the 10.5.8 was never released for those models...I'll probably recommend you wait it out until the next official upset is released.
  9. Swejuggalo
    Lollipop Jun 3, 2020
    Swejuggalo , via OnePlus 8 Pro , Jun 3, 2020 :
    How did you test the multi touch? I tested 10 multipoint touches.
    https://play.google.com/store/apps/details?id=com.gombosdev.displaytester
  10. Sinnaz0709
  11. S1591141085496
    Cupcake Jun 3, 2020
    S1591141085496 , via OnePlus 7 Pro , Jun 3, 2020 :
    Hi thanks, yes I used that and get 3 touches max almost all of the time. (The screenshot gesture is off). However, rarely all 10 points can briefly be activated and I can't say why (I haven't changed anything). It's very unusual. I did a full factory reset and still the same.
    Also missing many screen touches e.g. typing, and ghost touches e.g. extra keys being activated when tying , including the other side of the keyboard. This persists all the time and typing is very difficult.
    I have to assume it's a hardware / digitiser issue if others don't have these symptoms. That's what I was hoping to find out.
  12. JaY_III
    Donut Jun 3, 2020
    JaY_III , via OnePlus 8 Pro , Jun 3, 2020 :
    10.5.8 was 100% release for North America.
    10.5.9 was the mistake update not available to many with the only change according to the change log was disabling the IR camera..
    Don't waste time looking for 10.5.9 as it add nothing of value.
  13. Hamize
    Cupcake Jun 3, 2020
  14. Swejuggalo
    Yes that sounds like some hardware defect
  15. S1591141085496
    Cupcake Jun 3, 2020
  16. Swejuggalo
    I'm on 10.5.8 EU firmware. Might be hard to messup so much that max 3 multipoints only work via software. No impossible but I doubt it. So it's more credible that it's a hardware issue.
    I might have a slight touch issue, for example A button. But that might be something I just need to get used to and the problem goes away by itself.
  17. AndiTheBassman , via OnePlus 8 Pro , Jun 3, 2020 :
    I have tried myself and 10 simultaneous touches are no problem with my phone on 10.5.8 (haven't tried more due to lack of fingers)
  18. JoseReyes69
    Sinnaz0709 likes this.
  19. Swejuggalo
    Was sitting in the sun today. In direct sun light and maximum brightness. Pretty hot (for Sweden atleast, 20°C according to the weather rapport). Since I read about some with heat issues in similar temperatures and direct sun light I figured I might get the same. No issues at all.
    Also desided to run a thermal throttling test. Nude (the phone. Not me). Inside approx 22°C.
    Fairly decent. Hot peaks. Even after 15 minutes still pleasant to hold. Biggest preformance drop was due to some background activity. End result was well beyond acceptable to me. With decent ambiant temperature this seems fairly OK for gaming.
    Approx 40 seconds later
  20. Swejuggalo
    L1 on my 10.5.8 EU phone with this Netflix version
    JelleZon likes this.
