36
OxygenOS 10.5.8 [IN], 10.5.7 [EU] and 10.5.9 [NA] for the OnePlus 8
  1. Kanji Kher
    Donut Jun 30, 2020
  2. AthulXavier
    Cupcake Jun 30, 2020
    AthulXavier , via OnePlus 8 , Jun 30, 2020 :
    I'm barely getting 7 hours of screen time with this so called 4300 mah massive battery....... and if the device is used consecutively for 30 mins it starts heating......
    Battery is draining by 5% overnight with mobile data and all other apps in off condition
    Will this be solved with software update
  3. AdrianFischer
    Gingerbread Jul 1, 2020
    AdrianFischer , Jul 1, 2020 :
    Usually, I get the updates at least within a few days or maximum a week after it has been announced. Now this update was released a month ago and still, it doesn't show on my device. Something strange is going on here.
    5% battery drain in 8h~ night is not much. That's totally fine and acceptable imo.
    I'm getting 11h Screen On Time but I also don't have Snapchat, Instagram or Facebook installed which are battery killers.
  4. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 1, 2020 :
    I think those that haven't got it by now simply will skipp it and will jump to the next directly
  5. Ching_Nam_Ip
  6. AthulXavier
    Cupcake Jul 1, 2020
    AthulXavier , via OnePlus 8 , Jul 1, 2020 :
    not in 8hrs bro..... 5 hrs....
    and I'm only having watsapp and instagram.... no other social media apps.....
    will there b any update to fix this issue???
  7. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 1, 2020 :
    I see WhatsApp mentioned over and over again as a source of battery issues... For some it runs havoc completely.
    Some social media is also pure hell on regards to battery usage.
    Sometimes the user needs to deside what to prioritize...Do you really need all the features enabled (for example location tracking)? Is instant notifications important? Can you use optimize mode? Do you need notifications at all? Do you even need the app version if the webapp/webpage can be used?
    There are many ways the apps you install affects the battery.
  8. M1572471268415
    Cupcake Jul 1, 2020
    M1572471268415 , via OnePlus 8 , Jul 1, 2020 :
    Yes indeed. OnePlus 8 here in Hungary, still on 10.5.6. Takes way too long.
    Orki666 likes this.
  9. Xisco97
    Cupcake Jul 1, 2020
    Xisco97 , via OnePlus 8 , Jul 1, 2020 :
    Same problem here, hope they fix it in this patch
  10. SteveCP
    Honeycomb Jul 1, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Jul 1, 2020 :
    Xisco97
    Same problem here, hope they fix it in this patch​
    Did you set your phone from a back up of a previous OP phone? May need to download Oxygen Updater and check that the phone isn't set as your previous phone in updaters settings, has happened to a couple of pro owners.
  11. Xisco97
    Cupcake Jul 1, 2020
    I did fresh start, since last update I got downgraded to L3 dunno why, contacted support and they told me we would get this problem fixed for the next update. Thanks anyways I'll try what you told me just in case.
  12. SteveCP
    Xisco97
    I did fresh start, since last update I got downgraded to L3 dunno why, contacted support and they told me we would get this problem fixed for the next update. Thanks anyways I'll try what you told me just in case.​
    Sorry quoted wrong person this was for the updates not DRM, that is due to be sorted in next update but if you roll back then it should be back to L1 until new update is available.
    Xisco97 likes this.
  13. SteveCP
  14. M1572471268415
    Cupcake Jul 1, 2020
    This is my first OnePlus phone so previous back up doesn't exist for me. I guess they just decided to postpone the EU update for some reason ...
  15. SteveCP
    Download oxygen updater from the playstore and see if it is available that way, this is an app and does not root your phone
    Orki666 likes this.
  16. Orki666
    Cupcake Jul 1, 2020
    Orki666 , via OnePlus 8 , Jul 1, 2020 :
    I have downloaded and currently it's showing that I can update. Sorry, maybe you know if I will uodate with oxygen and if the same update can be developed for EU , will I get the modified update from system update? Thank you
  17. SteveCP
    Swejuggalo likes this.
  18. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 1, 2020 :
    Oxygen Updater files = just manually downloaded OTA files.
    The app gave the devs the filenames from real OTA files. Devs verified and let other users download via app.
    SteveCP likes this.
  19. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 1, 2020 :
    What settings do the app show here?
    8 EU?
    Orki666 likes this.
  20. Orki666
    Cupcake Jul 1, 2020
    I mean the uodate under the same name can be posted for EU and oushed to the users, I was thinking if oxygen csn recognize it's new modified update or the same. It looks like there is a chance of the modification because it has been a long time of without update and maybe there is some issue they are trying to fix.
