238
OxygenOS 10.5.9 for the OnePlus Nord
  1. Kishoreklade , via OnePlus Nord Blue Marble , Dec 17, 2020 :
    I think that app is required for normal functioning of the mobile...however, it is problem with the new update...so it is better to uninstall the update rather than completely disabling the app...
  2. PradeepPlus
    Honeycomb Dec 17, 2020
    PradeepPlus , via OnePlus Nord , Dec 17, 2020 :
    Lot of users like me are facing this Google apps offline issue ever since we bought this phone. It's not just this recent update of Webview. Lucky you, it's working for you atleast.
    R1600080982812 likes this.
  3. S1604835784311
    Cupcake Dec 17, 2020
  4. manosdias
    Ice Cream Sandwich Dec 17, 2020
    manosdias , via OnePlus Nord Blue Marble , Dec 17, 2020 :
    What issue? This seems like a problem on your handset as other users aren't experiencing this issue. Try reporting the bug in the correct forum and see what OnePlus advice
  5. S1604835784311
    S1604835784311 , via OnePlus Nord , Dec 17, 2020 :
    The problem with my oneplus nord is that when I auto rotate my screen it does not come back to portrait mode even if that mode is kept on and moreover it gets stuck to only one landscape mode. please look into this matter as soon as possible it's very irritating
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Dec 17, 2020
    Caomhin , via OnePlus 6T , Dec 17, 2020 :
    All users here on the Community. You could try backing up your phone and then do a full Erase All Data factory reset to see if that can fix the issue.
    Or you can Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  7. manosdias
    I have never encountered this problem on the Nord or any other handset for that matter.
    Just report the bug to OnePlus as you won't get an answer on this forum.
  8. N1604722956990
  9. prathamesh_
    Froyo Dec 17, 2020
  10. prathamesh_
    Froyo Dec 17, 2020
  11. Pratik2299
    Froyo Dec 17, 2020
    Pratik2299 , via OnePlus Nord , Dec 17, 2020 :
    You must use rotation button which comes at the bottom corner of the phone when you rotate the screen to rotate it. If you use that then you have to switch back to portrait mode manually from the same button. If you are using auto rotation button from the drop down menu on desktop then there must be some problem with your device
  12. Lithin_Joseph
    Gingerbread Dec 17, 2020
  13. donpablos
    Froyo Dec 17, 2020
    VishnuRCU and N1597670493549 like this.
  14. Jaganko
    Gingerbread Dec 18, 2020
    N1597670493549 likes this.
  15. PradeepPlus
    Honeycomb Dec 18, 2020
    PradeepPlus , via OnePlus Nord , Dec 18, 2020 :
    Why do you need a power bank when your phone charges in an hour? I personally feel it's useless. Just saying 🙂
    D.Sai Suhail Baba and Jaganko like this.
  16. FF52
    Eclair Dec 18, 2020
    FF52 , via OnePlus Nord , Dec 18, 2020 :
    Hey... Install the android webview beta from playstore... After the latest update which came yesterday i think my google offline issue is resolved
  17. FF52
    Eclair Dec 18, 2020
    It worked until i messaged it here .... Nevermind[e]1f602[/e]
  18. PradeepPlus
