23
OxygenOS 101 #3 - Smile Capture, Fingerprint Photo, Pocket Mode
  1. Dibyajyoti Deb
    India Digital Media Specialist Staff Member Aug 20, 2018
    Dibyajyoti Deb , Aug 20, 2018 :
    Hello Folks!
    It's been a while since we refreshed OxygenOS 101, so here's 101 #3 where we explore camera features, and improved usability. This is an attempt to educate new users to OxygenOS, as well as a refresher for existing users of OnePlus about the possibilities with OxygenOS. Do more with less!
    1. Smile Capture
    Smile Capture is a unique feature tucked away in camera settings. OxygenOS is all about doing more with less, and at every step, our developers are always focused on improving the experience of how you interact with the software. Smile Capture was built for this purpose. At times it gets difficult to take a steady selfie, wind blowing too fast? Friends jostling around you to get into the frame? With Smile Capture it is easier to click that perfect selfie by just smiling and letting the camera do the rest. Enable this camera setting to automatically take photos when you smile.
    2. Fingerprint Photo
    Following the lines of Smile Capture is Fingerprint Photo. This unique feature lets you click a smooth image by long pressing/touching the fingerprint sensor. Just place your finger over the sensor for 2-3 seconds and the camera auto captures the image in front of you. Nifty, for when you can't hold your phone with two hands for a stable shot, like while moving in a car maybe? With this gesture enabled, its easier to click photos with one hand.
    3. Pocket Mode
    We've all had instances of ghost dialing someone from our pockets or accidentally triggering off an app that ends up draining our battery without our knowledge, to being confused why music started playing randomly while your phone isn't even outside. Pocket touches are common occurrences and quite annoying at times. Enable the Pocket Mode to prevent this from happening. With advanced sensor programming OxygenOS knows when your phone is in your hand and when inside your pocket. So no more accidental touches or ghost calls!
    Hope you found this iteration of OxygenOS 101 useful. As always, we'll be sharing more tips and tricks for your OnePlus device for the best possible smartphone experience! Let us know through comments if you enjoyed this section and suggest some more tips and tricks you have discovered!
  2. kundan kumar
    Donut Aug 20, 2018
  3. F_Rakesh_Roshan_Rana_QCK
    Honeycomb Aug 20, 2018
  4. Evgeny.S
    Gingerbread Aug 20, 2018
    Evgeny.S , Aug 20, 2018 :
    Is the Fingerprint Photo available on the oneplus 6 exclusively? Because I've never seen this toggle on the stable build of oneplus 5 nor in the beta.
    Swapnilsg1 likes this.
  5. AcmE85
    Ice Cream Sandwich Aug 20, 2018
    AcmE85 , Aug 20, 2018 :
    You maybe know or maybe don't know that pocket mode is partly broken at the moment:
    It does not block the fingerprint reader from scanning inside the pocket.
    Some were complaining about constant scans when the reader registered their leg's skin through the fabric.
    Needless to say that this causes an annoying vibration, lights up the display after a few attempts and also locks the reader eventually so users end up with having to type in their pin/pattern.
    As the bug persists since OOS 5.1.9 and wasn't fixed on 5.1.11, please fix this.
    Thank you
    (I'm using a fitbag so I'm not even affected, but should be a quick fix!)
  6. srinivas0301
    srinivas0301 , Aug 20, 2018 :
    Does this post make any sense ,Users pissed off with the latest update 5.1.11 as nothing been improved and even gone worse .
  7. itsTejtarun
    Eclair Aug 20, 2018
    itsTejtarun , Aug 20, 2018 :
    Have you Disabled the On body detection in Smart lock section if
    not then try this one's.
  8. C1518333364236
    Donut Aug 20, 2018
    C1518333364236 , Aug 20, 2018 :
    phone gets unlocked by face recogination even while wearing helmet that means just eyes distance they have algorithm if something more secure can be updated!
  9. MKT_IRFAN3735
    Jelly Bean Aug 20, 2018
    C1518333364236 likes this.
  10. karan1683
    Froyo Aug 21, 2018
    karan1683 , Aug 21, 2018 :
    Pocket mode is to stop the phone from getting unlocked on it's own while in pocket. If ur touching the finger print scanner you are actually unlocking the phone by yourself.
  11. Eeshan_Bhave
    Froyo Aug 21, 2018
    Eeshan_Bhave , Aug 21, 2018 :
    are you sure that's Face Unlock and Not Smart Unlock? there's a difference you know. Just search around the forum
  12. C1518333364236
    Donut Aug 21, 2018
    C1518333364236 , Aug 21, 2018 :
    we have face unlock right ? 1+5 T
  13. Eeshan_Bhave
    Froyo Aug 21, 2018
    yeah but you also have smart unlock which opens the device based on outline of the face. Go to Settings > Security. you'll see that there's a face unlock and then there's a smart unlock too.
  14. C1518333364236
    Donut Aug 21, 2018
    yes it is face unlock ! not smart one..
  15. G_plusone
    Marshmallow Aug 21, 2018
    G_plusone , Aug 21, 2018 :
    Just open Settings and read the explanation for Pocket mode in your OnePlus phone
  16. Suraj_Biswas_ji
    Cupcake Aug 21, 2018
    Suraj_Biswas_ji , Aug 21, 2018 :
    My phone is hanging out so I did not make money because the phone hangs it takes better iPhone 7 plus [e]1f621[/e]
  17. Sashikumar100
    Eclair Aug 21, 2018
    Sashikumar100 , Aug 21, 2018 :
    guys there is no recent changes after oxygen os update ... nothing to do with change logs everything remains d same
    still we have to press ok to unlock after inserting the pin
    stil my phone gets hang seni connect to my car bluetooth
  18. G_Manoj_kumar_vrhM
    Gingerbread Aug 21, 2018
    G_Manoj_kumar_vrhM , Aug 21, 2018 :
    This used to happen before. But not now bro.
  19. B.yashaswi
    Ice Cream Sandwich Aug 22, 2018
  20. Z1534477777850
    Cupcake Aug 22, 2018
