281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. H1572770740818
    Donut Apr 21, 2021
  2. Akhil Palla
    Donut Apr 21, 2021
    Akhil Palla , via OnePlus 7 Pro , Apr 21, 2021 :
    I suggest u not to update to new version its very bad nd it has a lot of bugs which annoy u all the time.
    Bhatsaurabh07 likes this.
  3. AarishRaza
    Cupcake Apr 21, 2021
    AarishRaza , Apr 21, 2021 :
    akks
    As it's said to be cancelled, in the opening post, there should be many. Why, you wanted that one?​
    No but hope that I get this asap
    how is the new update by the way ?
  4. oniltimalsina
  5. DHAVAL@1989
  6. akks
    KitKat Apr 21, 2021
    akks , Apr 21, 2021 :
    Some face bugs even in this release, better to wait for the staged rollout. You may go through a few posts in this thread to know the feedbacks from those who already installed it.
  7. rashcourse
    Donut Apr 21, 2021
    rashcourse , via OnePlus 7 , Apr 21, 2021 :
    After updating my Oneplus 7 to Oxygen OS 11.0.0.2 which came as an OTA update I faced some major issues which I want to address.
    1. There is a considerable amount of UI lag when browsing an app or changing from app to app. Also there is a stutter/lag while opening any App (Be it in Ram or not).
    2. Haptics are messed up.
    Before update the haptics felt more fulfilling. But after update it feels hollow and lasts longer which felt like a cheap vibration.
    3. In camera app The Video Recorder when set to 1080p/4k 60FPS the video is as usual zoomed in(Just like in Android 10). However the output video is much wider, Even more wide area is visible which was not there in the viewfinder while recording.
    This issue is not there when video set to 1080p/4k 30fps
    4. Heating issue.
    Even though using the phone casually and not doing any heavy task the phone feels warm and heats up. While playing games like Call of Duty temperature goes 45+ degrees which was not there when using Android 10.
    5. Battery drain
    Battery drains pretty quickly even though battery management is properly done. Like dark mode, auto brightness turned on and standby time is also reduced.
    6. Charging delay
    The battery charges slow even though Dash charger is used. and the last 30% takes much more time. (This was not in the case on Android 10)
    I hope people can relate to the issues and the issues get addressed by Oneplus in their future updates.
  8. T1570806397976
  9. RaviRam9523
  10. Shekhar_29
  11. E1562857001168
    Donut Apr 21, 2021
    E1562857001168 , Apr 21, 2021 :
    I have not received update of android 11 yet..Can some please suggest when do I get update for that
  12. I1567934312540
    Adilsha4 likes this.
  13. Sourav_G_7668
  14. R.ajz
  15. Vihang Dasadia
    Donut Apr 21, 2021
    Vihang Dasadia , Apr 21, 2021 :
    I hope this bug fix update is good,
    I'm waiting from such a long time for Android 11 and I want that to be smooth without any bugs so that I don't have to face any issues.
  16. Singh4ankur
    Donut Apr 21, 2021
    Singh4ankur , via OnePlus 7 Pro , Apr 21, 2021 :
    Not worth it wana go back
    WiFi issue keeps disconnecting
    Signal are less
    Scrolling seems 60hz now
    Few more minor things hard to express but I regret updating I should have waited
    Ashish900 and Softcubs like this.
  17. Singh4ankur
    Donut Apr 21, 2021
    I regret updating
  18. Singh4ankur
    Donut Apr 21, 2021
    They are busy with there new devices
