281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Vysyas666
    Cupcake Apr 21, 2021
  2. NithinMahesh@123
  3. G1577244887741
  4. beyondocean
    Gingerbread Apr 21, 2021
  5. KishanGarach
  6. marcmcvitie
  7. R1618901446596
    R1618901446596 , Apr 21, 2021 :
    just wanted to check if I am doing the right thing. checked my device but it has not recieved the update yet. may I know when will the update be available..
    Julian Holznagel likes this.
  8. R1618901446596
  9. Netsky60
    Honeycomb Apr 21, 2021
  10. jstoneM
  11. Swimp79
    Swimp79 , Apr 21, 2021 :
    I have the Oneplus 7T PRO Mclaren Edition and i updated to Android 11 and the phone is getting hot and slugish when i use it. Even with the latest update fix its getting slugish. Think i might roll back to Android 10 when it worked like it should.
    Regret that i updated it...
    Adilsha4 likes this.
  12. rajamcs
    Eclair Apr 21, 2021
    rajamcs , via OnePlus 7 Pro , Apr 21, 2021 :
    After update, my wifi connection is not stable. It's keep getting disconnecting. Need a quick fix immediately. Not a experience OnePlus promised.
  13. RaghwendraPratap
    Eclair Apr 21, 2021
    RaghwendraPratap , Apr 21, 2021 :
    My OnePlus 7 didn't received Oxygen OS 11 till now.
    Anyone have idea when this update will come to my device ?
  14. naveen.davalagar
  15. Sooraj1803
  16. R1618901446596
    hi.. I am using 1 plus 7t.. I have a flickering issue when I try to use the slow motion option... can anyone suggest a fix pls..
  17. R34llyLucky
    Eclair Apr 21, 2021
    R34llyLucky , via OnePlus 7 , Apr 21, 2021 :
    MAJOR WIFI disconnecting issue... It keep disconnecting and reconnecting automatically... I have DISABLED the "Intelligently select the best Wi-Fi" as well...
    PLEASE PROVIDE A FIX ASAP!!!
    rajamcs and Arvind__Singh like this.
  18. Ehud1699
  19. Adilsha4
    Adilsha4 , via OnePlus 7 , Apr 21, 2021 :
    The battery is draining very fast after the update. No warp charge, it even charges very slow. Phone is heating more than before while using. Please consider and fix the bugs.
  20. B1575190435169
