281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Blckstrxx
    Froyo Apr 22, 2021
    Blckstrxx , Apr 22, 2021 :
    Wifi keeps on disconnecting after this update and its really frustrating. Why do you release a build without testing in beta properly as a stable release.
  2. 7797459800
    Cupcake Apr 22, 2021
  3. Z1581451989889
  4. Prabhas786
    Ashish900 likes this.
  5. sk.jalal05
    Froyo Apr 22, 2021
    Tedinetto likes this.
  6. Z1598196427659
  7. fcarmona
    Gingerbread Apr 22, 2021
    fcarmona , Apr 22, 2021 :
    I had more o less the same problem as you.
    Switching from 90Hz to 60Hz and smallest width 452 dp, (under developer options) it solved my problem.
  8. Ishan920 , via OnePlus 7 Pro Nebula Blue , Apr 22, 2021 :
    I did change the smallest width 440 dp because this new update kinda seemed too big then what i am used to but that didn't work either, and honestly i did everything i could to sort it out but nothing worked so far, switched the fps, resolution, font size the display size, even changed the gestured and navigation mode, but its all the same
  9. Sureshj95
    Sureshj95 , via OnePlus 7 , Apr 22, 2021 :
    I will say one of the most shitiest update from OnePlus in OnePlus 7 device.
    Really hate this...
  10. O1583490040652
    Froyo Apr 22, 2021
  11. V1577175300011
  12. Venkatesh00794
    Eclair Apr 22, 2021
    Venkatesh00794 , via OnePlus 7 , Apr 22, 2021 :
    Do not update A11 still buggy I,m using 11 stable version 2 hot fix but they not fix anything so don't
  13. H1579145116506
    H1579145116506 , via OnePlus 7 , Apr 22, 2021 :
    Sir mujhe issues aa rahe hai updation k baad
    Phone Heat
    Photos Late Khul Rahi Hai
    Camera Quality Bhi Kamm Hogyi Hai
    Battery Jaldi Drain Ho Rahi Hai
    Mere Phone Mein Contacts 10 Times Ho Gye Aur Delete Bhi Nai Ho Rahe
    Venkatesh00794 likes this.
  14. joshilal07
    Eclair Apr 22, 2021
  15. H1579145116506
    Sir Maine Update Kiya Hai Aur Same Issues Aa Rahe Hai
  16. MjDinesh
  17. Atik_waghela
    Atik_waghela , via OnePlus 7 , Apr 22, 2021 :
    How can i roll back.. The new update sucks.. The black color is no longer black which was the oneplus's signature. Please help me roll back. The simplicity which one plus had has finished
  18. Stealth777
    Stealth777 , via OnePlus 7 Pro Nebula Blue , Apr 22, 2021 :
    Is the standard with 411 ?
