270
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Artemus.
    Community Hero 2020 Apr 22, 2021
    Artemus. , Apr 22, 2021 :
    Back up your stuff and reset your phone.
  2. mohsinsaiyad
    Cupcake Apr 22, 2021
  3. akashrajpal
    Eclair Apr 22, 2021
    akashrajpal , via OnePlus 7 , Apr 22, 2021 :
    I'm on beta4. I wouldn't get a stable update notification right? It would be a good feature to have.
    When shall the website have the full stable version? Still shows 10 there.
  4. CTRL_FR34K
    CTRL_FR34K , via OnePlus 7 Pro , Apr 22, 2021 :
    Anyone who wants to roll back to 10 here's how to do it:
    Rolling back wipes data, though you can take a backup using OnePlus Switch or Google Drive backup. Download one of the OxygenOS versions you want:
    https://onepluscommunityserver.com/list/Unbrick_Tools/OnePlus_7_Pro/. You’ll need a Windows PC, and make sure you choose the correct region.
    Read the instructions as well!!!: https://onepluscommunityserver.com/list/Unbrick_Tools/OnePlus_7_Pro/README.txt.
    chrisval likes this.
  5. L1619113618595
    L1619113618595 , via OnePlus 7 Pro , Apr 22, 2021 :
    I am not able to change the clock on ambient display after the update. No matter which clock style I choose, it still only shows the default clock style. Does anyone have this problem? How do I fix this issue?
  6. DARPAN8
  7. J1571643704732 , via OnePlus 7 Pro , Apr 22, 2021 :
    So, is it safe , I mean like as before android 11?
  8. CTRL_FR34K
    Yes I've had to do several times after trying the original 11 multiple times( hoping that after a full wipe and re-download the original 11 would work properly).
    it'll reset you to 10 then just do the updates to 10.3.8 through the system settings
    J1571643704732 likes this.
  9. AhmedOman
    Donut Apr 22, 2021
  10. J1571643704732 , via OnePlus 7 Pro , Apr 22, 2021 :
    No,I mean about Android 10. I want Android 10 back as I even don't like the view of UI my phone getting slow. So about that i am asking. you shared that link for Android 10 so if I download that after that my phone work properly in Android 10 only.
    it's downloading... let me know after downloading complete.. what do we need to do.
  11. CTRL_FR34K
    Yes you will be back on Android 10. It's a true rollback. It's a actual process though to do it. It's not as simple as a standard updating process.
  12. J1571643704732 , via OnePlus 7 Pro , Apr 22, 2021 :
    Okay let me try... Nd will let you know If I am getting some error or whatever related with the updates. Thanks
  13. X1618990397814
  14. L33Toua
  15. Luarpc
    Honeycomb Apr 22, 2021
    Luarpc , via OnePlus 7 Pro Nebula Blue , Apr 22, 2021 :
    It's up to you. I'm on OxygenOS 11, GM 1913 European Version without no issues, everything is working great. On OxygenOS 11 you have the latest patch security (March) from Google, there's no big difference from 10, you have different features. On 11 we lose immersive mode. It will return on 12 if 1+ give us as a gift upgrade. 😉There are many users here, that have updated from 10 to 11 and they are complaining about Bluetooth, internet connection, DPI, screen resolution, battery drain, and so on. That's not my case, i've updated from 9 out of the box to 10, then to all 10 Open Beta builds, then to 11 and to this one 11 hotfix, for me it wasn't a hot fix, i never had any problem since i updated from 10 to 11 full update. Last Monday i received OTA update (incremental) to this latest build. So, it's up to you, if you want to update, go for it and if you have any issue you can rollback to 10 but make a full backup first cause the rollback package will erase your data. There are many tutorials on internet. Cheers.
    P1565936042723 likes this.
  16. Sayooj mk
  17. mohsinsaiyad
  18. Insane_Butcher , via OnePlus 7 Pro Nebula Blue , Apr 22, 2021 :
    Guys, this is insane. Check my previous post (when I was making certain tweaks to improve the battery life) and this is today's result + 15% battery left. I am back to dynamic theme - dark mode gets enabled in the evening, QHD. I don't know how to explain this, but I am having +1 hour of SOT.
    Luarpc likes this.
  19. Krishnan S
    Eclair Apr 22, 2021
  20. Zex85
    Gingerbread Apr 22, 2021
    Zex85 , via OnePlus 7 , Apr 22, 2021 :
    i easily get 8+ sot if i am not playing games only social media apps youtube etc.. with pubg i get 3.30 to 4 sot with a single charge
    flither likes this.
