281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Netsky60
    Ice Cream Sandwich Apr 23, 2021
    Netsky60 , Apr 23, 2021 :
    You can change it in setting (set them to the max)
  2. M1619093001440
    Cupcake Apr 23, 2021
  3. Netsky60
    You're welcome ;)
  4. Chetan0222
  5. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Apr 23, 2021
    Artemus , Apr 23, 2021 :
    Yep, this is an issue with this specific build on this specific model. You'll have to downgrade and wait for the next update (maybe 11.0.0.3 or 11.0.1.0?) for this issue to be fixed.
    M1619093001440 likes this.
  6. M1619093001440
    M1619093001440 , via OnePlus 7 Pro , Apr 23, 2021 :
    Thanks, think I'll suffer through it for now
  7. JayeshRaghani
    Donut Apr 23, 2021
    JayeshRaghani , via OnePlus 7 , Apr 23, 2021 :
    Disable optimized charging feature and than it will get charged fast
    T1570024183543 likes this.
  8. L1523785145335
  9. Shiva_Rohith
    Honeycomb Apr 23, 2021
    Shiva_Rohith , via OnePlus 7 , Apr 23, 2021 :
    Also , do we get bimonthly security update ..as this is considered a late update and a hotfix.... can we expect anything? Bimonthly security patch?
  10. Artemus
    Yes, the bi-monthly updates will still come out as they always have.
    Insane_Butcher likes this.
  11. Saqlane
  12. T1570024183543 likes this.
  13. B1610575328976
  14. aristle.jm , via OnePlus 7 Pro Mirror Gray , Apr 23, 2021 :
    I got the update as well. Everything looks to work smoothly, but I agree with the point on haptics. It is a little hollow, probably due to added reverb... I think people prefer the earlier version more.
    The battery usage did increase compared to earlier, but I realised that it was because the phone was hot from the update with a battery temp of over 40°C. I cooped it down, and now it seems to be working pretty well.
    Live the Insight ambient screen...
    Default wallpapers still seem to be missing on update and the OnePlus team has not gotten back to me about this issue yet.
  15. GJM2
    Gingerbread Apr 23, 2021
    GJM2 , Apr 23, 2021 :
    But what a worry do you have with temperature device, buddies?
    -The general android rule says depending on your region that, up to 60° or lower, cpu is safe. More than 100° unsafe.
    -The general android rule says depending on your region that, from 35° to 50° battery percent is quite common. Above 50°, starts to be dangerous.
    So NOT, your phone is not overheating and that is not an issue.
    -Your device getting hot is quite normal when:
    1. You are charging it (dash mode usually).
    2. You are updating a new heavy OS.
    3. The first 4/5 cycles of charging after updating a new heavy OS.
    4. When playing or managing with heavy games or apps (that require high definition graphics).
    THE BEST THING TO KEEP SAFE YOUR BATTERY LIFE IS:
    -NOT keep charging battery when full charge is reached (100%).
    -NOT charge your battery below 15/20 charge percent (red mode).
    -TRY not to fully discharge the battery too many times.
    -USE your original charger device.
    -TRY not to expose and charge your device to hot or sun too much time.
    Hope that helps..
    Netsky60, tausif1590 and Gemilan like this.
  16. J1569854244980
    Eclair Apr 23, 2021
    Destro7 likes this.
  17. Imtheflash
    Donut Apr 23, 2021
    Imtheflash , via OnePlus 7 Pro , Apr 23, 2021 :
    I have some questions regarding this new update
    After the update when the display scaling and font size is set to small, chats in whatsapp and telegram still appear in normal size.
    This even applies for the settings panel.
    Has anybody felt the same issue?
  18. Netsky60
    Same here but i use the One7 Pro. I think the non-pro received a different firmware.
  19. Netsky60
  20. aziz25 likes this.
