281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Zex85
    Gingerbread Apr 24, 2021
    Zex85 , via OnePlus 7 , Apr 24, 2021 :
    You probably didn't read this thread well enough.. or you might came late, specific models are facing screen flickering issue and other bugs depends on your model no.
  2. TommyHammy
    Honeycomb Apr 24, 2021
    TommyHammy , Apr 24, 2021 :
    kill your battery? hahaha do you even know anything about AOD's?
    it takes a few percentage at most.
  3. surajit20
    Froyo Apr 24, 2021
    Kirill Kuzminykh likes this.
  4. lovepreet0012
    Cupcake Apr 24, 2021
    T1570024183543 likes this.
  5. B1577239984044
    B1577239984044 , via OnePlus 7 , Apr 24, 2021 :
    I updated my OnePlus 7 device to Android 11 on 23/04/21 and since then I'm facing screen flickering and screen blackout issues and also a lag in incoming call pop-up banner.
  6. G1578954267124
  7. Nyree
  8. akshayelencheran
    Froyo Apr 24, 2021
    akshayelencheran , Apr 24, 2021 :
    How did you roll back. Can you guide
  9. U1604472686617
  10. AhmedOman
    Donut Apr 24, 2021
    AhmedOman , via OnePlus 7 , Apr 24, 2021 :
    Bug after the update: when opening videos in whatsapp the top part containing senders name, date and time does not go away, even tapping or waiting will not help. It can be annoying especially when watching in landscape.
    Anyone facing this issue? How to solve it?
  11. Z1558408625753
  12. Arghya139
    Arghya139 , Apr 24, 2021 :
    I used to get all call recordings of any contact right from the call history
    Who do I have to kill to get that option back after 11 update ?
  13. Artemus.
    Community Hero 2020 Apr 24, 2021
    Artemus. , Apr 24, 2021 :
    I mean, you can start by blocking out the sender's number. It might also be a WhatsApp issue, try contacting them.
  14. AsadHaseeb
    Donut Apr 24, 2021
    AsadHaseeb , via OnePlus 7 Pro , Apr 24, 2021 :
    yes happened with me on my one plus 7 pro... and while playing pubg its getting too hot and throttling
  15. amitexe786
    amitexe786 , via OnePlus 7T , Apr 24, 2021 :
    It is also problem for me in 7t... In my case, in dark environment ambient display function does not working.
  16. F1577209069131
    Cupcake Apr 25, 2021
  17. Artemus.
    Community Hero 2020 Apr 25, 2021
    Artemus. , Apr 25, 2021 :
    Settings > Wi-Fi & internet > check to see if "Dual-channel network acceleration" is on. Next, same menu but go into "Wi-Fi", scroll down, tap "Wi-Fi preferences" and turn off basically all the things here.
  18. Rajat_kumar_95
  19. Artemus.
  20. Rajat_kumar_95
