281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Vipulruprela
    Cupcake Apr 26, 2021
    I1577483098614 likes this.
  2. BiOnicTecHie
    Gingerbread Apr 26, 2021
  3. ranbirchatha
    ranbirchatha , via OnePlus 7 , Apr 26, 2021 :
    Hii, Here are some issues I'm facing after recent update to android 11 in OnePlus 7
    1. The gboard settings for keyboard size are not working, always show same size. I need small one so it doesn't use much space of screen.
    2. Some times when I scroll doen to pick the call, it doesn't work. It takes exact drag and push to make it happen. Please make it smooth.
    3. The UI of new design is not much good. Using same settings for font size, but in new update font is appearing bigger.
    4. The notification bar background color is not sharp in dark mode.
    5. I was expecting filters in camera app but not available so will be better if you provide the same.
    6. The gallery app is most annoying now, it takes 10 to 15 seconds to load my images and till then all collections doesn't appear.
    Thanks!
    I1577483098614 and MoIcam like this.
  4. ranbirchatha
    One more point, can you provide the tap and hide the dialpad during a call, currently need to find a line in sunny day and then drag it down to hide the dialpad.
  5. R.Peter
    Ice Cream Sandwich Apr 26, 2021
    R.Peter , via OnePlus 7 Pro Mirror Gray , Apr 26, 2021 :
    Of they are vanished, we can't help. There's no way to restore, except if you created backups about them (for example to Google Drive).
  6. I1577483098614
    I1577483098614 , via OnePlus 7 Pro , Apr 26, 2021 :
    Please Don't update to 11.0.0.2 it has lot's of BUG..no charging sound, call quality blur, ringing volume decreased, Msg sound decreased, Calling display coming to 2 line mode, AOD removed..call recorder shows after recording even off to show..lot more, heating issue...
  7. C1619172918266
    C1619172918266 , via OnePlus 7 Pro , Apr 26, 2021 :
    New problem. While the phone is still glitching like crazy, now I literally cannot lock the phone, because if I do, I cant unlock it again. I have to do fastboot mode and restart my phone again to regain access to it. I already purchased the OnePlus 8 because this isn't going to get better. It really is bs, this phone is barely a year old since I purchased it, I deserve my money back. I did everything possible to protect this phone, and the software is what undoes it 😒.
  8. Linkin1994
    Honeycomb Apr 26, 2021
    Linkin1994 , via OnePlus 7 Pro , Apr 26, 2021 :
    This is not true
    GJM2 likes this.
  9. dkumarnamburu
    dkumarnamburu , via OnePlus 7 , Apr 26, 2021 :
    Volume level is reduced to low after updating to OS 11. Notification sound for messages and Incoming call ringing volume too is reduced to low level.
    DhavalA likes this.
  10. xythiii
    xythiii , Apr 26, 2021 :
    Wifi disconnects,
    Overheating
    Frame drop
    Sound its lower,
    Vibration haptic is lower,
    Oneplus has messed up this update.... True disappointment as oneplus fan.....
    Yunusrg, Naarshan, Tetro and 4 others like this.
  11. GJM2
    Netsky60 likes this.
  12. girlboz
    girlboz , via OnePlus 7 Pro , Apr 26, 2021 :
    I'm not able to change the clock type in the lock screen after upgrade and also it shows 24 hours format even if I had selected 12 hours. Moreover my battery life is very bad after update. It drains so fast . Let me know how to fix this
  13. girlboz
  14. Linkin1994
    My 7 pro perfect so
  15. F1619422765750
    F1619422765750 , via OnePlus 7 Pro , Apr 26, 2021 :
    If I activate ambient display, sometimes I do still get the big content size problem, and it only occurs if I select qhd resolution, even I wiped all positions. I'm very disappointed as it has been my first oneplus device. I came from a pixel 2...
  16. I@Shafi
    I@Shafi , via OnePlus 7 , Apr 26, 2021 :
    Is anyone facing issues with the device heating up during charging post the Android 11 update? Also the charging time seems to have gone up post the update...
    JithuMohan83 and moti786 like this.
  17. GJM2
  18. rwmchan
    Jelly Bean Apr 26, 2021
    rwmchan , Apr 26, 2021 :
    After upgrading 11.0.2, it was found that the screenshot function was missing in the power menu. where did it go?
  19. nicv
    Eclair Apr 26, 2021
    nicv , via OnePlus 7 Pro , Apr 26, 2021 :
    After the update... of the update the phone randomly has hiccups. Not smooth sometimes. I don't have disconnections or overheating but it is annoying. I have faced it in two or three apps and while unlocking to use use the camera by double clicking the power button. It just went black.
    There must be updates I believe and hope
    Tetro likes this.
  20. roshannair87
    roshannair87 , Apr 26, 2021 :
    After updating my OnePlus7, i have started facing lot of issues. Scrolling isnt as smooth as it used to be earlier and the device seems to heat up even with bare minimum use at times. Battery seems to drain quickly and the charging has become pretty slow. Device doesnt wake up as quickly as it used to with the double tap or pressing the side button. How to get this fixed up? Its becoming very annoying :mad: The previous versions were much better :(
