281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. N1579557858359
    Cupcake Apr 28, 2021
    N1579557858359 , Apr 28, 2021 :
    Update won't let me switch screen without closing current screen. I have to back out. Dislike
  2. karim.Fadel
    Gingerbread Apr 28, 2021
    thlengane likes this.
  3. wipner
  4. Appurockz0831
  5. Netsky60
    Ice Cream Sandwich Apr 28, 2021
    Netsky60 , Apr 28, 2021 :
    Try a A10 rollout
  6. thlengane
    Donut Apr 28, 2021
    Anks Lee likes this.
  7. R.Peter
    R.Peter , via OnePlus 7 Pro Mirror Gray , Apr 28, 2021 :
    Every battery drains. Just like your cells. It is because everything uses energy.
    Netsky60 likes this.
  8. thlengane
    Donut Apr 28, 2021
  9. GJM2
    GJM2 , Apr 28, 2021 :
    Hey man. I agree with you, but I think you did not read enough the thread.
    It is said several times here, that Factory Reset is not going to solve your software issues but it is HIGHLY recommended when you update a heavy OS. Above all, in order to avoid some conflicts among your back up restore, apps, software & hardware functions, etc.
    And, even better than that, Factory Reset your device BEFORE install your update and DO NOT restore anything. Just install what you need again and that's all.
    The problem here is that people do not read, only complain.
    And secondly, it is also known Indian update has several problems, the EU update is mostly ok.
    You can download the EU zip update from Oxygen Updater or from some direct links as XDA Developers or some other on-line google pages.
    FOR INDIAN USERS WITH ISSUES WITH UPDATE 11.0.0.2:
    Go here (at the final page)..
    https://www.xda-developers.com/oneplus-7-7-pro-7t-7t-pro-stable-oxygenos-11-android-11/
    And download and install your EU (Europe) OP 7 needed version until next Indian stable version is rolled out.
    Please, feed back your update experiences.
    Cheers..
  10. Zex85
    Zex85 , via OnePlus 7 , Apr 28, 2021 :
    Wrong thread
    Artemus likes this.
  11. F_Eshan_Sharma_KqFJ
    Cupcake Apr 29, 2021
    F_Eshan_Sharma_KqFJ , via OnePlus 7 , Apr 29, 2021 :
    Since the update, there has been a problem with all incoming calls. The incoming calls appear after almost 5 seconds of ringing. Dont know how to remove this bug. Pls help.
  12. LokGubhaju
    Froyo Apr 29, 2021
  13. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Apr 29, 2021
    Artemus , Apr 29, 2021 :
    Well, that's pretty rude to say.
  14. karim.Fadel
    Gingerbread Apr 29, 2021
    karim.Fadel , via OnePlus 7 Pro , Apr 29, 2021 :
    Is this will wipe data or not if I update from local update
  15. Ashmeet2614
    Donut Apr 29, 2021
    Chetan0222 likes this.
  16. thlengane
    Donut Apr 29, 2021
    thlengane , via OnePlus 7 Pro , Apr 29, 2021 :
    Same issue here, I thought I was the only one. Even my watch gets the incoming call notifications a few seconds before it appears on the phone. Battery drainage is another massive problem for me, all of a sudden I am getting a lot of Apps notifications that they are draining the battery. Even without these notifications, I now find myself charging twice a day, which never happened before.
    F_Eshan_Sharma_KqFJ likes this.
  17. thlengane
    Donut Apr 29, 2021
    Anyone getting the black screen when you swipe out the Google Assistant ambient mode while charging? Here is how it happens:_
    1. Enable Google Assistance ambient mode
    2. Lock your phone
    3. Plug the phone into charger, this will turn on Google Assistant ambient mode
    4. Swipe the Google Assistant ambient mode out, the phone will give you a Black screen with only the notification
    5. You will have to double tap on the black screen
    to get to your normal lock screen
  18. thlengane
    Donut Apr 29, 2021
    Been getting the same issue as well, sometimes it is stable.....but at times it goes haywire with connecting and reconnecting the WiFi network
  19. ra1016 , via OnePlus 7 Pro T-Mobile , Apr 29, 2021 :
    Very well said. The second paragraph describes exactly how I performed my update, and I now have the Android 11 update with zero bugs.
  20. DiegoPepperoni
    DiegoPepperoni , via OnePlus 7 Pro , Apr 29, 2021 :
    Hi. I just updated my Oneplus 7 pro to Oxygen OS 11. After the update my wifi connection keeps disconnecting and reconnecting. At first i thought it was my router. However, the same thing happens even when im connected on a different wifi router. Please help. It is very annoying and very disruptive.
