271
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. nicv
    Eclair May 4, 2021
    nicv , via OnePlus 7 Pro , May 4, 2021 :
    Another bug just appeared from nowhere. I have set my phone to lock the screen after 1 minute. It suddenly decides by itself to change that time to 15 secs.
    I am starting to believe that this is the worst update ever considering mostly the bad reviews from a lot of you here, plus I dont have a smooth operation as I used to...
    the_reckoner and Vishal_Mallick like this.
  2. O1583490040652
    Eclair May 4, 2021
    O1583490040652 , May 4, 2021 :
    Wow that your forced to update, so the a11 how is it on your phone any bugs?
  3. O1583490040652
    Eclair May 4, 2021
    Cool 😁
  4. Vishal_Mallick , via OnePlus 7 Pro , May 4, 2021 :
    1620114442221.jpg View attachment 1617860
    1620114442379.jpg said:
    Even Nexus 6 (2014 launched with Android 5) running on Android 11 is less buggy.. I mean zero bugs.. didn't find one & LOS says no bugs, thanks LineageOS 😂😂😂😂😂😂 though not smooth as OP but you can use it as daily driver, no extreme heating, all apps are working fine high end games not playable so that can't be played with OP7p😂😂😂 kudos OP... There is tsunami of complaints OP just keeping silent.. at least withdraw the update.. A10 was good, btw OP do you remember Cynogenmod???
    the OnePlus 1 was launched with this OS fyi...
    s.suri97 likes this.
  5. s.suri97
    Donut May 4, 2021
    starboy1910 likes this.
  6. ra1016
    Froyo May 4, 2021
    ra1016 , May 4, 2021 :
    Fortunately in my case no bugs. Everything is running smoothly. OnePlus 7 Pro T-Mobile unlocked model GM1915. Your results may vary. I also used one of those Android repair apps from the Play Store that was rated about 4.5 stars a week or so later, and now everything feels even smoother than it did right after the update.
  7. O1583490040652
    Eclair May 4, 2021
    That's good, android repair apps?
  8. Raghava2706
    Gingerbread May 4, 2021
    Raghava2706 , via OnePlus 7 Pro , May 4, 2021 :
    https://forums.oneplus.com/feedback
    Please provide your views in that link. This is completely a public forum and no dev teams are monitoring this. Bug hunters are there to just collect bugs details. But most of the users who updated are facing same issues.
  9. s.suri97
    Donut May 4, 2021
  10. OleAsbjørn
    Cupcake May 4, 2021
  11. YashPanchal097
    Donut May 4, 2021
    YashPanchal097 , via OnePlus 7 , May 4, 2021 :
    Yesss broo
  12. YashPanchal097
    Donut May 4, 2021
    Having this same issue overheating & fast battery drain😞
    starboy1910 and E1592318225451 like this.
  13. Arun_K91
    Donut May 4, 2021
    Arun_K91 , via OnePlus 7 , May 4, 2021 :
    *Wifi keeps disconnecting *
    After the recent update 11.0.0.2 wifi keeps on dropping. I have tried factory reset, wifi connection reset however it still the same. One more issue is there auto-brightness feature is also not working the way it should be everytime I have to manually correct the brightness level. These are the main concern out of others.
  14. T1620116077921
    Cupcake May 4, 2021
    T1620116077921 , via OnePlus 7 Pro , May 4, 2021 :
    I am big fan of One plus series. BUT this update 11 i shit. I have never see so BAD and ugly update. Please do something and give us update 10 back. If not i will never buy one plus anymore
  15. T1620116077921
    Cupcake May 4, 2021
    G_Xia_Min_De_QjdK and s.suri97 like this.
  16. Mohsinmulla
    Eclair May 4, 2021
    Mohsinmulla , via OnePlus 7 , May 4, 2021 :
    Same here
    G_Xia_Min_De_QjdK likes this.
  17. A1574539437363
    Cupcake May 4, 2021
    A1574539437363 , via OnePlus 7 , May 4, 2021 :
    Hello everyone I have some troubles scince I did the update, my phone restart randomly and sometimes become very slow. I don't know what to do to fix this 😓
    If someone have any suggestions 🙏
