260
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Shoeb4all
    Donut May 4, 2021
  2. hsharma2k
    Cupcake May 4, 2021
    hsharma2k , via OnePlus 7 , May 4, 2021 :
    I am facing lot of Wifi disconnection issues on my One plus 7 after the upgrade. It is veri irritating and after every minute I have to manually go to wifi setting and connect it. Please resolve this.
    ifr33t, moti786 and V1573641241262 like this.
  3. thiagostocco
    Donut May 4, 2021
    thiagostocco , via OnePlus 7 Pro , May 4, 2021 :
    This is surprisingly working! Thank you so much!
    GJM2, Shvetan and Luarpc like this.
  4. Luarpc
    Honeycomb May 4, 2021
    Luarpc , May 4, 2021 :
    :laughing::laughing: Conspiracy Theory!!!
    Don't just say it, prove it!
    OnePlus just slow down phones with Global and Indian ROMs, not EU! That's Discrimination! :smiley::smiley:
    And yes, after the update you have to do 4 rechargeable cycles to stabilize the battery and improve apps, and that is not a lie!!!
    Battery analysis and battery drain trouble solving. - OnePlus Community
    charging, battery, performance, caches and battery calibration myths busted - OnePlus Community
    GJM2 and moti786 like this.
  5. Luarpc
    You're Welcome. I'm glad it solved your WI-FI issue!
    thiagostocco likes this.
  6. DDekker84
    Cupcake May 4, 2021
    DDekker84 , May 4, 2021 :
    Hello,
    Yesterday I've updated my device with OxygenOS 11 11.0.0.2.GM57BA
    Ever since that update whenever the phone connects to my car (KIA Picanto 2019 model) with android auto, there is no sound coming through, neither from Navigation apps nor Spotify. If I select the speaker instead of bluetooth as output, there is sound. Also connecting my Raycon earbuds work. But the combination with Android Auto does not.
    Android Auto versions used:
    6.3.611324-release
    6.1.610533-release
    6.0.615313-release
    Spotify version:
    8.6.22.1112
    Waze version:
    4.73.0.3
    How can I resolve this issue? Its really annoying the shit out of me.
  7. ifr33t
    Cupcake May 4, 2021
    ifr33t , via OnePlus 7 Pro , May 4, 2021 :
    I partially agree. But I'd not blame OnePlus as vendor and developers, because it could also depend how Snapdragon 855 and Android 11 are compatible on hardware level. In case of Apple, Apple had full control of every hardware and software, next iOS release felt less optimized for past hardware, Apple is fully responsible for it. But OnePlus only adapts existing technologies (CPU, OS), which they do not control and develop fully on their side. Maybe this is the case.
    Artemus. and GJM2 like this.
  8. GJM2
    Gingerbread May 4, 2021
    GJM2 , May 4, 2021 :
    Not my case. I have enough when I lose my phones just to buy a new one, no way. My OP 7 Pro is almost 2 years old. I'm praying for not to lose it, at least until the new OP 10/11 Pro with fully 5G connection will appear.
    ra1016 likes this.
  9. P1574330958319
    Cupcake May 4, 2021
    P1574330958319 , via OnePlus 7 Pro , May 4, 2021 :
    J'ai quelques problèmes depuis la mise à jour. Les applis système (one plus launch ou encore téléphone) on tendance a s'arrêter en fonctionnement, le téléphone ne peux plus être déverrouillé et
  10. TommyHammy
    TommyHammy , May 4, 2021 :
    speak English
    P1574330958319 likes this.
  11. P1574330958319
    Cupcake May 4, 2021
    I have some bade issues since the last update, some applications like phone or oneplus launch can't run.
    Also, my phone shut down itself and restart later.
    This kind of problem never happen before, it's only since the last update ...
  12. Goyathlay
    Donut May 4, 2021
    Goyathlay , via OnePlus 7 Pro , May 4, 2021 :
    Updated à couple hours ago to the french eu version OP 7 Pro and everything is ok so far. Nice and smooth. I cant even notice about a faster battery drain.
    Luarpc likes this.
  13. nits1688
    Cupcake May 4, 2021
    nits1688 , via OnePlus 7 Pro , May 4, 2021 :
    I am facing wifi disconnect issue often after I have installed the update..
    Wifi keeps getting disconnected Unnecessarily , I think there is some bug in update which needs to be fixed
    How can we fix this ..
    Really big issue for me
    Awaiting urgent reply
  14. Shinjuurou
    Eclair May 4, 2021
    Shinjuurou , May 4, 2021 :
    If you take a look at the most recent update for the oneplus 9, you will find many people complaining at the same performance and battery problems. So they also slow down the recent phones so that people do what again? Also the eu version looks fine. Hwy kwhy would the implement such slow down only in the other versions? This whole thing makes no sense. In my opinion it's much more reasonable to assume they rushed the update, maybe even corona made then problems...
    Luarpc likes this.
  15. NuVirus
    Cupcake May 4, 2021
    NuVirus , May 4, 2021 :
    For me the EU OTA Update was fine, but i did a Full Wipe to clean up my phone and apps.
    First time after buying it 2020, but i did the clean setup yesterday so not a long time.
    Seems fine right now, also Warp Charge is Working - no exact time between 10 and 11, i usually load the battery with a multiport USB Charger and normal charge Speed.
    So far no problems with WLAN, but not tested much so far.
    Luarpc likes this.
  16. Luarpc
    Luarpc , via OnePlus 7 Pro Nebula Blue , May 4, 2021 :
    For all the people having issues with Wi-Fi disconnect issues try this until a hot fix from OnePlus. I'm not having issues with Wi-Fi disconnect.
    Go to Phone settings, click on Wi-Fi & Network, click on your Wi-Fi SSID network name, click on advanced, click on network usage and change it from auto to "Treat as unmetered".
    Hope it helps.
  17. Aleeamir2
    Cupcake May 5, 2021
    Aleeamir2 , via OnePlus 7 Pro , May 5, 2021 :
    with Oxygen11 update my oneplus7pro performance got effected alot my gallary is taking time to load camera quality is poor fome has abnormal brightness and sometimes fone responds late when i open blocked contacts the phone app gets closed automatically
    i was excited about oxygen11 but all my excitement is gone i want to roll back to oxygen10 that was far far better then oxygen11
    Oneplus you disappointed us with your OXYGEN11 your developers have failed to create something which is better then oxygen10 please give us oxygen10 as we were happy with good camera and performance of the phone
    Sanket_Shivgan likes this.
  18. KDKid
    Eclair May 5, 2021
    KDKid , May 5, 2021 :
    Not true at all. Clearing the cache may speed things up a bit, but won't do anything about...
    - decreased battery life
    - 90hz refresh rate not working
    - screen brightness
    - wifi issues
    - most other bugs or glitches
    An update of this magnitude should not have the laundry list of issues. That is, unless it comes from CD Project Red. (Too soon!? Haha)
  19. xxTheShadow
    Cupcake May 5, 2021
  20. H1620178652926
    Cupcake May 5, 2021
    H1620178652926 , via OnePlus 7 Pro , May 5, 2021 :
    Ooof what an update.
    -Taking a picture takes so much longer.
    -Making edits to the picture of even cropping a picture takes so much time to save afterwards.
    -the UI of the phone settings looks weird.
    -Notifications in the notifications bar reappear after swiping to get rid of them and then disappear as if there was a delay.
    Bierten77 and Vishal_Mallick like this.
