260
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Sanket_Shivgan , via OnePlus 7 Mirror Gray , May 5, 2021 :
    Same here 😭😭😭😭😭
    Bierten77 and Vishal_Mallick like this.
  2. shijuvas
    Donut May 5, 2021
    shijuvas , via OnePlus 7 , May 5, 2021 :
    I've an issue that when i switching data from sim 1 to sim 2 it is not working properly, you have to restart the device for proper data. Kindly tell if somebody know the solution 🙏
    Vishal_Mallick likes this.
  3. spsinghrajput
    Cupcake May 5, 2021
  4. Aru0506
    Cupcake May 5, 2021
    Aru0506 , via OnePlus 7 , May 5, 2021 :
    Dear Team. I have updated my 1+ 7 with this update, i have frequent losses & disconnect in wifi, gsm & bluetooth networks. this litterally makes my phone un usable, could you please take a look at this. I have connected support and didreset of network settings & cache.. but the problems remains Kindly have a quick fix roll out. Or let me know how to rollback.
    Bierten77 likes this.
  5. rittik_vashisht
    Cupcake May 5, 2021
    shijuvas likes this.
  6. ashishmal27
    Cupcake May 5, 2021
    ashishmal27 , via OnePlus 7 Pro , May 5, 2021 :
    Got it, upgraded too. But my phone has become Very Very Slow after the upgrade. I have One Plus 7 pro 8 gb 256 gb grade.
    Kindly guide if I am Doing something wrong. It was Perfect before the Upgrade.
    Kindly update
  7. Shaoyang
    Gingerbread May 5, 2021
    Shaoyang , via OnePlus 7 , May 5, 2021 :
    do backup and then hard rest
  8. subashswarna
    Cupcake May 5, 2021
    subashswarna , via OnePlus 7 , May 5, 2021 :
    I didn't get my update till today....... Since its been a month oxygen os 11.0..0.2 was released but I didn't get it 🥺🥺🥺😤😤😤😤😤😤😤
  9. ManxkandanMS
    Cupcake May 5, 2021
    ManxkandanMS , via OnePlus 7 , May 5, 2021 :
    You're not alone!!! I too haven't received the update yet. Maybe they paused the broader roll out of the update due to negative feedbacks. I hope to receive it sooner once OnePlus fix the bugs and other issues.
  10. Mr.Sgm
    Eclair May 5, 2021
  11. ashishmal27
    Cupcake May 5, 2021
  12. ashishmal27
    Cupcake May 5, 2021
  13. Thirumal Kumaran
    Thirumal Kumaran , via OnePlus 7 Pro , May 5, 2021 :
    Feel.lucky you haven't got it...!
    aziz25 and ashishmal27 like this.
  14. Abhik.b02
    Froyo May 5, 2021
    Abhik.b02 , May 5, 2021 :
    Hello good folks of the community!
    See this prompt, it's laying here since a week now.
    This is the third time I got the notification. I had updated the OS to the new version, used for a good 1.5-2 weeks and then reverted to OOS 10.3.8 on my OnePlus 7, thrice!!!
    Hear me out. Please do not rush in updating your device to this version. I have written few posts in this community as to the bugs I'm experiencing and reported to the Dev's.
    I couldn't bear the OS any further. I had all my data backed up in cloud, so factory reset is not a problem. OOS 10.3.8 is by far the best OP has published for this handset.
    To my surprise, my trusty old Nexus 7 from 2013 handles Android 11 with Lineage OS just fine, even with ancient hardware. I use it as my Kindle and occasional YouTube. Point being, OnePlus 7 series can last a long way!
    See, technology should work for you and not the other way round. If the device works well in OOS 10.3.8, I would urge not to update to the latest flavour of OOS yet. Kindly bear with the dated security patch. It would turn out to be better than fussing over new jitters/bugs that the new OS introduces.
    Closing thoughts: There are few elements in the UI that I greatly appreciate. Personally, I wouldn't mind too much using the new UI, given it's snappy and responsive (barring few instances in OOS 11.0.0.2). If I were you, I would seriously wait for them to iron out the bugs before jumping on the new update now. The SoC, IMO is still relevant and can easily last a couple of years more, given OnePlus doesn't mess around with the OS releases any further.
  15. Mr.Sgm
    Eclair May 5, 2021
    Mr.Sgm , via OnePlus 7 Pro , May 5, 2021 :
    Bro how to downgrade to 10.3.8 from 11.0.0.2 please advise
  16. Abhik.b02
    Froyo May 5, 2021
    ashishmal27
    Even I would like to go back
    I hear you! I have done this thrice after updating to OOS 11.
    Following is the procedure to downgrade to OOS 10.3.8. It works for me, but hear me out. It will WIPE the entire device! Please proceed if you are ready to go ahead with a fresh install like this. There's no workaround, sadly.
    1. Search for rollback package for OnePlus 7/7pro on the internet and download the zip file, move it to root folder, not in the downloads folder.
    https://oxygenos.oneplus.net/OnePlu...all_2010191035_downgrade_e2f201f3007f4e85.zip
    [e]261d[/e]️ This should be the link for OnePlus 7.
    https://oxygenos.oneplus.net/OnePlu...all_2010191035_downgrade_22b70083812944e2.zip
    [e]261d[/e]️This should be the link for OnePlus 7 Pro.
    2. Go to settings, hit local update and you should click the file you had just downloaded. a word of caution, it will factory reset the device, make sure you have a backup.
    3. Your phone should now be running OOS 9.5.2, Android 9!
    4. Download Oxygen updater app from play store now.
    5. It will help you download OOS 10.0.3, if I remember correctly, it's a patch update to have your device on board with Android 10.
    6. Once that's done, you should get an OTA for OOS 10.3.8. If not, manually search for update in settings.
    7. That's it! It's good old 10.3.8!
    Hope, this helps! Good day!
    Sudarshan_Sadavarte likes this.
  17. ashishmal27
    Cupcake May 5, 2021
    Will try for sure. Thanks a Lot
  18. Abhik.b02
    Froyo May 5, 2021
    Hi buddy! Check the post above, I have broken down the downgrade process into steps.
    Hope this helps!
  19. Abhik.b02
    Froyo May 5, 2021
    Anytime! Happy to help!
  20. Mr.Sgm
    Eclair May 5, 2021
    This link that you have provided is for OnePlus 7.
    Thank you for your efforts mate
    But it is not for me as my phone is OnePlus 7 pro
