260
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Abhik.b02
    Froyo May 5, 2021
  2. O1583490040652
    Eclair May 5, 2021
    O1583490040652 , May 5, 2021 :
    Hahahahah good one
  3. Gourang19
    Froyo May 5, 2021
    Gourang19 , via OnePlus 7 , May 5, 2021 :
    Received the update! And it was freaking owsm also for the ones who were concerned about battery - battery drop is that noticable though
  4. Bierten77
    Froyo May 5, 2021
    Bierten77 , via OnePlus 7 , May 5, 2021 :
    Same problem here...
  5. G1578491401061
    Cupcake May 5, 2021
  6. Haku_
    Cupcake May 5, 2021
    Haku_ , May 5, 2021 :
    i am using open beta4, is there any update that changes into stable android 11 in newer update or we have to roll back and update to android 11???
  7. akks
    KitKat May 5, 2021
    akks , May 5, 2021 :
    Didn't you read before you moved to beta channel. Check opening post of beta 1 thread.
  8. Python_Dev
    Gingerbread May 5, 2021
  9. AayushManak
    Donut May 5, 2021
    AayushManak , via OnePlus 7 , May 5, 2021 :
    . I'm requesting you to please provide me an stable OS 11 for oneplus 7, because my system UI is crashing everyday, which is very disgusting for me, so please provide me stable update of Oxygen OS 11 for oneplus 7.
    As soon as possible, it's a request.
    haryp2309 likes this.
  10. U1604472686617
    Froyo May 5, 2021
  11. M1619870949396
    Eclair May 5, 2021
    dgnbrk likes this.
  12. Marco Rabitti
    Cupcake May 5, 2021
  13. H1561476019849 , via OnePlus 7 Pro , May 5, 2021 :
    After 11 and 11.0.0.2 updates swipe up from the bottom of the screen to see resent used apps in gesture control not working and also when call comes it takes 3 to 4 sec to screen onn as to see who's call is coming and the main problem battery is draining very very fast .. S.O.T 3 to 3.5 hrs .. OP pl rectify this problems in next update..
    spsinghrajput likes this.
  14. N1574359630811
    Cupcake May 5, 2021
    N1574359630811 , via OnePlus 7 , May 5, 2021 :
    I'm facing the issue after the android 11 update on OnePlus 7.
    Issues
    • wifi disconnected
    While using the wifi on a close range wifi signal gets disconnected frequently
    •heating issues
    With the normal use phone heats noticeably, without gaming
    •auto reboot
    Device reboot automatic while scree lock to locking by pressing power button happens 5 times a day
    Are you guys facing the same issues after the update??
    I have never faced these issues on Android 10 and older device on OnePlus 6 updates to android 10.
    spsinghrajput and Sagarshaikh like this.
  15. TommyHammy
    Honeycomb May 5, 2021
    TommyHammy , May 5, 2021 :
    ha ha ha. You think that will make them listen?
    ashishmal27 and Naarshan like this.
  16. TommyHammy
    Well that's your own fault, there are hundreds of people on here warning people not to update because of bugs. People choose not to do a tiny bit of reading before updating to a completely new OS.
    GJM2, flither and ashishmal27 like this.
  17. Veridis1
    Cupcake May 5, 2021
    Veridis1 , via OnePlus 7 Pro , May 5, 2021 :
    reset your phone👍
    ashishmal27 likes this.
  18. G_Surya_Bista_knLY
    Cupcake May 5, 2021
  19. akks
    KitKat May 5, 2021
    Better to wait for the next one. This isn't good
  20. D1566310177432
    Eclair May 5, 2021
