281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Burhan Damat
    Cupcake May 9, 2021
    Burhan Damat , May 9, 2021 :
    Hello there. I can't watch netflix hd after the oxygen 11 update either. I lost the L1 certificate. does anyone have a solution?
  2. U1605811464649
    Cupcake May 9, 2021
    U1605811464649 , via OnePlus 7 , May 9, 2021 :
    Every morning on my One Plus 7 after the alarms, mobile gets hanged and I'm not able to do any activity on any of the apps . I need to restart my mobile every morning after the latest update(to Oxygen 11.0.0.2). Can you let me know if there is any way to get out this ?
  3. Z1511278517115
    Cupcake May 9, 2021
    Z1511278517115 , via OnePlus 7 Pro , May 9, 2021 :
    I have same problem. Also texts don't downloading.
  4. N1576140242262
    Cupcake May 9, 2021
  5. N1576140242262
    Cupcake May 9, 2021
  6. fahimnewaz
    Donut May 9, 2021
    fahimnewaz , via OnePlus 7 , May 9, 2021 :
    Too much battery drain on this update. Overheating issue is resolved, but I am annoyed by the amount of battery drain on this update
  7. santhoshk09
    Donut May 9, 2021
  8. barnabyj
    Honeycomb May 9, 2021
    barnabyj , via OnePlus 7 Pro , May 9, 2021 :
    Be nice if they rolled out the phone call speaker fix to everyone. I made sure to not get my phone from t-mo to get updates faster. Irony.. lol That's really the only bug I have. And the selfie camera pop up animation not being centered correctly. 🙃
  9. pcpremengg
    Froyo May 9, 2021
  10. Ishmeet_Kandhari
    Cupcake May 9, 2021
    Iamdarklord likes this.
  11. ra1016 , via OnePlus 7 Pro T-Mobile , May 9, 2021 :
    Hopefully it means that OnePlus has already found a fix for the phone speaker issue and will be including it in the next update. I didn't have that issue to begin with, so I'm not able to tell for sure if it was actually fixed. But at least they have acknowledged it.
  12. H1565532533832
    Donut May 9, 2021
  13. H1565532533832
    Donut May 9, 2021
    H1565532533832 , via OnePlus 7 , May 9, 2021 :
    I have had the same issues, my phone was like a ball of fire and battery life was a pain in ss. I formatted my phone and everything be ok now.
    Hard reset your phone and clean cache, format everything.
  14. Shaoyang
    Gingerbread May 9, 2021
  15. TommyHammy
    TommyHammy , via OnePlus 7 Pro , May 9, 2021 :
    My Chromecast works fine after the new update
  16. H1565532533832
    Donut May 9, 2021
    CAPTAIN ONEPLUS HERE!
    Listen everyone: if you have thermal and battery life issues after the last update just hard reset your device, wipe cache, reset system settings and Erase everything then reboot. Thats all. You'll see your phone will be as charming as before.
    Vinny_jammula likes this.
  17. TommyHammy
    You shouldn't have to do that with an official update. I never did and my device is fine.
    I think most over heating issues are down to user apps, I see a lot of people playing PUBG and call of duty mobile, then reporting heating issues.
    Maybe it's those apps which are not optimized for Android 11.
    As said, I've had zero battery and zero overheating problems.
  18. YD98
    Eclair May 9, 2021
    YD98 , via OnePlus 7 Pro , May 9, 2021 :
    Its been almost a month still not received the update (OnePlus 7pro Indian version).
    The android 11 update is the worst update you people have pushed. Battery drain is too high and app glitches everywhere. Even gallery app loads slowly typically like a 2 GB Ram phone.
    aymusbond likes this.
  19. _Singh_
    _Singh_ , via OnePlus 7 Pro , May 9, 2021 :
    To those who are unable to remove media player from Quick settings Panel.
    From above image swipe right/ left and click on gear icon, you will be redirected to below page said:
    Just Toggle it ON, player would be automatically remove from quick settings panel.
    GJM2, Raghava2706 and Netsky60 like this.
