281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. aymusbond
    Cupcake May 9, 2021
    aymusbond , via OnePlus 7 , May 9, 2021 :
    Thanks. I see that there are other people with the same problem.
    But I couldn't find a solution for it in recent posts. Any chance you know if OnePlus is aware about this (and working on it) or the post which gives a solution?
    It's difficult to got through 5k+ posts and the search option didn't yield any solution post.
  2. akks
    KitKat May 9, 2021
    akks , May 9, 2021 :
    Wait for the next build. Should be fixed in that
    aymusbond likes this.
  3. Netsky60
    Honeycomb May 9, 2021
    Netsky60 , May 9, 2021 :
    Thanks !
    Singhji21 likes this.
  4. Rajan06
    Gingerbread May 9, 2021
    Rajan06 , via OnePlus 7 , May 9, 2021 :
    Bug Noticed
    Screen saver is working fine before this update.
    But now when I charge my device it is now showing the clock even though it has been in charging and docking mode
  5. vineetn12
    Eclair May 9, 2021
  6. mebroj
    Cupcake May 9, 2021
  7. Lucky_Sharma
    Lucky_Sharma , via OnePlus 7 Pro , May 9, 2021 :
    Pressure??? Nop bro if they have pressure then why they not reply, why they close this update and stop spreading this garbage update to other user.
  8. Lucky_Sharma
    U used ur phone for calling and seeing video and surfing that's it nothing else that's why u didn't feel any difference.
  9. Lucky_Sharma
    I downgrade my phone from Android 11 to Android 10. And I am happy now.
    ashish960 likes this.
  10. paradox_1plus
    Donut May 9, 2021
  11. Zex85
    Zex85 , via OnePlus 7 , May 9, 2021 :
    Scrolling through community forum app just to reach oneplus 7 fourm now this phone feels really old 😂😂 needs to be changed
  12. swyrik
    Donut May 9, 2021
  13. ashish960
    Tobi 97 likes this.
  14. wipner
  15. Maddy996 , via OnePlus 7 Mirror Blue , May 9, 2021 :
    Would suggest you to wait for atleast next incremental update, I'm also still holding OS10
  16. N1580138131911
    Cupcake May 9, 2021
    N1580138131911 , via OnePlus 7 , May 9, 2021 :
    Bonjour,
    Depuis la mise a jour je rencontre des soucis de stabilité avec l'affichage.
    Parfois le téléphone plante complètement et redémarre.
    C'est particulièrement gênant au quotidien...
    Une solution ou un patch peut être ? Merci
  17. Blue llama
    Eclair May 9, 2021
    Blue llama , via OnePlus 7 Pro , May 9, 2021 :
    I had increased I increased battery drain for a few days than it went away
  18. F1580046805993
    Cupcake May 9, 2021
    F1580046805993 , May 9, 2021 :
    Report it on oneplus 7 pro, during the video call (WhatsApp) reduced to an icon, the mobile phone undergoes a drastic slowdown during the scrolling of the apps, the use of social networks. Update 11.0.0.2 anyone reporting the same problem? Solutions?
  19. F1575336599139 , via OnePlus 7 Pro , May 9, 2021 :
    After updating to "Android 11" 11.0.0.2 continuously facing multiple issues. This is the biggest joke update ever "Android 11" stay clear from this abomination.
    OnePlus is my favorite phone for countless years and for them to come out with this... Words can't describe the annoyance of things not working properly when you desperately need them to work. Start fixing the problems or unfortunately, sadly this will be the last phone I ever purchased from OnePlus.
    Problems facing...
    Sending text message via messaging app and trying to include a photo to send never sends only says "sending"... forever. Need to take a photo with your camera app and attach it to your text for it to work the in-app camera for messaging takes a photo but doesn't send it.
    Extremely poor Network reception, words can describe the frustration.
    Battery drain much quicker.
    While recharging phone it becomes extremely hot this could be a potential hazard if the battery explodes I'm sure you'll be facing a lawsuit if by any chance this might happen.
    For convenience purposes you can no longer just hold down the power button to take a photo... You really want to start pissing people off don't you with this ridiculous method of holding the power button and volume down at the same time you take a photo.
    No longer have favorites to choose from for text messaging app, need to manually scroll through your contacts and pick a person, mind numbing...
    Opening certain apps like my trading account hangs for at least 10 seconds or more before letting me input password or fingerprint to login. If needed to sell or buy something immediately well you can't anymore that 10 + seconds can cost you.
    I'm sure there's countless other issues out there that people are facing. This is truly sad. Please get together with your Tech team and push out a rollback update to the latest Android 10 non beta which will not factory erase your phone.
