281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Nirvedh
    Cupcake Apr 18, 2021
  2. parth31051477
  3. Adi_2019
    Ice Cream Sandwich Apr 18, 2021
  4. Lezwin Fernandes
    Donut Apr 18, 2021
  5. gdsingh94
    Jelly Bean Apr 18, 2021
    gdsingh94 , via OnePlus 7 , Apr 18, 2021 :
    You have to manually install the stable update... And you will lose all your data in this process... Download the latest stable full update file using oxygen updater and manually install it..
    Lezwin Fernandes likes this.
  6. nimeshsolanki
    Eclair Apr 18, 2021
  7. Rushikesh Bhosle
  8. Fenil.Patel
    Venkatesh00794 likes this.
  9. sahilrana
    Gingerbread Apr 18, 2021
  10. barlarkris
    Donut Apr 18, 2021
  11. wipner
  12. Venkatesh00794
    Eclair Apr 18, 2021
  13. Venkatesh00794
    Eclair Apr 18, 2021
  14. Python_Dev
  15. Insane_Butcher
    Honeycomb Apr 18, 2021
    Insane_Butcher , via OnePlus 7 Pro , Apr 18, 2021 :
    Make sure to place the installation package in the root folder. Then go to settings -> system -> system updates -> click gear icon ⚙️ -> local upgrade and you should be able to see the file you downloaded. Then just follow system installation.
    GJM2 likes this.
  16. Python_Dev
  17. Insane_Butcher
    These 2 issues that you've mentioned have been resolved in the hot fix. At least should have been. Kindly check whether you have installed 11.0.0.2.
  18. Y1577801271189
    Donut Apr 18, 2021
