281
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. R.Peter
    Ice Cream Sandwich Apr 18, 2021
  2. _Singh_
    Honeycomb Apr 18, 2021
  3. surajit20
    Froyo Apr 18, 2021
  4. AMZATH91
    Cupcake Apr 18, 2021
  5. Jiaul1901
    Donut Apr 18, 2021
  6. Shounox
    Donut Apr 18, 2021
    Shounox , via OnePlus 7 Pro , Apr 18, 2021 :
    2 major issue identified ... Battery heating. Screen on time on full charge reduced to 3 hours 56 mins from 4 hours 30 mins earlier. Normal uses.
    Wifi / Internet frequently getting disconnected.
    Sampad Roy likes this.
  7. Shounox
    Donut Apr 18, 2021
  8. AntunC
    Donut Apr 18, 2021
  9. OneplusLover.
    Gingerbread Apr 18, 2021
  10. imyuraviniki143
    Subham_S likes this.
  11. Subham_S
    Froyo Apr 18, 2021
    Sahilk0369 likes this.
  12. Netsky60
  13. _Singh_
  14. surajit20
    Froyo Apr 18, 2021
  15. Satrajit Chakraborty
    Satrajit Chakraborty , via OnePlus 7 , Apr 18, 2021 :
    If you are facing issues then you have to provide them feedback by using the feedback tool and also by uploading logs which they will ask once you raise the issue. Highlighting here won't help as they don't check our messages much for bug hunting.
    Also point number 7 is neither a bug nor anyone should have any issue with that. Else the other points are valid👍🏻
  16. Satrajit Chakraborty
    These are the exact problems which I am still facing after the latest hotfix build but may vary for other users.
    I guess its Google's issue, chances of Oneplus's optimization issues are less. I provided them with logs before the release of the hotfix, but none of them seems to be fixed.
  17. Netsky60
    reddevil55 likes this.
  18. OneplusLover.
    OneplusLover. , via OnePlus 7 Pro , Apr 18, 2021 :
    But official oneplus service center says that , manually updating the device is like sacrificing your device !
  19. Netsky60
    Netsky60 , via OnePlus 7 Pro , Apr 18, 2021 :
    They said it to avoid bad firmware update.
    If you choose the good one then there's no problem.
