255
OxygenOS 11.0.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. GJM2
    Gingerbread Apr 19, 2021
    GJM2 , Apr 19, 2021 :
    You and thousands of people.
    I don't know the politics of some forums.
    In Spain, spammers users are directly banned in most of forums.
    What a hell on earth!
  2. akks
    KitKat Apr 19, 2021
    akks , Apr 19, 2021 :
    Pls go through a few posts above yours and you'll get to know
  3. Kochumon07
    Cupcake Apr 19, 2021
    F1566111390193 likes this.
  4. 7982227281
  5. Insane_Butcher
    Honeycomb Apr 19, 2021
    Insane_Butcher , via OnePlus 7 Pro , Apr 19, 2021 :
    Hello there. Check my post #240.
    I haven't noticed any heating issues regardless of my activity. I have listened to music, streamed , played games, recorded videos, scrolled the timeline in Twitter, Reddit and I can say that the smartphone doesn't even get warm. Even while playing PUBG for 40 minutes or so. I remember how smartphone was getting hot in Pubg on early versions of Android 10. The difference in performance may be caused by something I am not fully aware of. Seems like GM1910 models don't have much troubles.
    leoyinjou likes this.
  6. Insane_Butcher
    You are basically mocking the forum users. One or Two posts above yours fully explains the reason you haven't got an update. Please learn to read the opening post attentively.
  7. GJM2
    Agree. I have a GM1910 also. Not problems at all with OS11 update 11.0.0.0
    leoyinjou and Insane_Butcher like this.
  8. 9001270497
    Donut Apr 19, 2021
    9001270497 , via OnePlus 7 Pro , Apr 19, 2021 :
    when i open pung after 2 or 3 minutes 43 or 44 degree
  9. SWATHI A1589228558181 , via OnePlus 7 Pro , Apr 19, 2021 :
    It did bring new user experience, but it have got few bugs as well, i use oneplus 7 pro , and the smooth scrolling which is speciality os oneplus is gone for me, even app drawer have scroll lag now, hope they fix this, not sure if its just me who got this issue, also got this excessive heating and battery drain issue now, which was not there before
  10. MORFYRD
  11. Q1595954016286
    Froyo Apr 19, 2021
  12. wipner
    Froyo Apr 19, 2021
    wipner , via OnePlus 7 Pro , Apr 19, 2021 :
    No I updated first to android 11 then I tested it.
    What do you mean that's it gives a higher score?
  13. akashrajpal
    Eclair Apr 19, 2021
  14. Adi_2019
    Adi_2019 , via OnePlus 7 , Apr 19, 2021 :
    It's normal. Google released two patches. You will get one more update. After that date will change to 1 April.
  15. Insane_Butcher
    Report it using available reporting tools. I would do it this way:
    1) Screenshot of the screen before the temperature begins to grow clearly showing the current temperature and the time.
    2) Open application that impacts your smartphone and make a screenshot once the application responsible for identifying the state of internal parts detects a significant/abnormal increase in temperature. Again the temperature and time should be visible as long as these parameters show how fast the smartphone gets hot.
    3) Send screen grabs to bughunters@oneplus.com + report the issue using reporting tool.
    After it's done I would recommend to rollback to Android 10. It's the only way to continue utilizing your smartphone without issues.
  16. M1560335188599
    M1560335188599 , Apr 19, 2021 :
    When you updated to 11, did you do a factory reset before or after the update, and/or did you do a global cache wipe?
    I'm still on 10, and I am reluctant to update to 11 because of all the bug reports rolling in, even after the 11.0.0.2 patch.
    BTW, my phone is a GM1913.
  17. Namitrajsingh
    Namitrajsingh , via OnePlus 7 , Apr 19, 2021 :
    Could you ping me the link of that thread it would b a great help ?
    Thanks
  18. M1600955206417
  19. Insane_Butcher
    Kindly check my post #240 in this thread to get an idea of my experience with Oxygen OS 11.
    I was on Oxygen OS 11 Open Beta 4, rolled back to Stable Oxygen OS 10.3.8. which required full data wipe. Once 11.0.0.2 became available I haven't made any additional manipulations apart from installing the new update through Oxygen Updater.
  20. Insane_Butcher
    GM1913 models might have overheating and increased battery consumption issues, so I would still recommend to check with other users and hold a little.
