250
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. Z3R007
    Gingerbread Apr 21, 2021
    Z3R007 , via OnePlus 7T , Apr 21, 2021 :
    My crystal ball says that you are destined to receive the update on 2nd May at 22:22 hours. You need to keep the phone facing north and charged fully to receive the update.
    BTW, my crystal ball is made by OnePlus 😁
    McJader likes this.
  2. Navin42
    Cupcake Apr 21, 2021
  3. ghostofcain
    Marshmallow Apr 21, 2021
    ghostofcain , Apr 21, 2021 :
    Can you not back it up in safe mode? The fact that safe mode works tells you it's a 3rd party app at fault.
    What google photo issue, working fine for me, but it was on 11.0.
    No issues here for the EU build, and wasn't with 11.0.
  4. Jatinkumar Patel
    Eclair Apr 21, 2021
  5. W1578073507533
  6. Aaron2017
    KitKat Apr 21, 2021
    Aaron2017 , Apr 21, 2021 :
    I can't say for sure, but it would seem at least the EU rom is mostly spared from a lot or major issues. I'm from Europe and got both the first and this update and they both worked fine so far.
  7. Aaron2017
    KitKat Apr 21, 2021
    Staged roll-out, might take a week or 2 or more even to fully roll out
    McJader likes this.
  8. kãräñ_90564
    kãräñ_90564 , via OnePlus 7T , Apr 21, 2021 :
    There was the issues in google photos in loading images in os11.0.0.2
    But now It got solved after I Hard reset my OnePlus 7t from recovery as advised by OnePlus service expert.
  9. O1570644648193
  10. Oksygen
    Oksygen , via OnePlus 7T , Apr 21, 2021 :
    I got the EU model, and do not have any problems at all.
  11. PaulBuckle
    Froyo Apr 21, 2021
    PaulBuckle , via OnePlus 7T , Apr 21, 2021 :
    Though, a lot of complaints, Google photos, for example, is working for me, I use it a lot, no heating issue. Charging, obviously I use it, again no heating issue. If the complaints were about apps I never use, then yes, I would agree, but it just strikes me as odd that different country versions appear to have serious issues for some apps, which are fairly standard to the phone.
  12. kãräñ_90564
  13. ghostofcain
    As I say not had an issue with Google photos ony device, if a hard reset sorted it maybe some residual config issues from previous build?
    Use a different, more configurable, launcher?
  14. McJader
    Lollipop Apr 21, 2021
    McJader , Apr 21, 2021 :
    As has been said already a thousand times in this thread, it is a staged Rollout, may take a week or two or even more to reach you.
    Please have patience and don't contribute in cluttering this thread.
    devourerOfBits80 and Aaron2017 like this.
  15. W1578073507533
    W1578073507533 , Apr 21, 2021 :
    but my friend have it... that's why I'm so impatient
  16. Q1594045097976
  17. McJader
    It is a random staged rollout buddy.
    devourerOfBits80 likes this.
  18. Q1594045097976
  19. singhManpreet
    Eclair Apr 21, 2021
    singhManpreet , via OnePlus 7T , Apr 21, 2021 :
    Mine is working fine. As I have not used any cloud backup either on Google drive or OnePlus. But yes for me battery issue is present. Previously it was almost whole day I could survive with one full charge, with gaming and normal usage. Now only 6-7 hours.
    vigneshwaran. likes this.
  20. ghostofcain
