267
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. Aaron2017
    KitKat Apr 21, 2021
    Aaron2017 , Apr 21, 2021 :
    Then update it again? Mine is on april now
  2. vigneshwaran.
    Eclair Apr 21, 2021
    vigneshwaran. , via OnePlus 7T , Apr 21, 2021 :
    i also don't have backup in drive cloud even Google photos
  3. saurabh2655
    Cupcake Apr 21, 2021
    saurabh2655 , Apr 21, 2021 :
    how much days does it take to rollout update to every single device
    still using os 10 and Android 10
  4. E1576777952383
  5. GaneshAkg
    Eclair Apr 21, 2021
    GaneshAkg , via OnePlus 7T Pro , Apr 21, 2021 :
    Anybody any issue battery backup and gallery app.. these are the main issue I'm facing.. gallery app doesn't whatsapp image download videos.. battery backup before android 11 I got around 5 to 5:30 screen on time with QHD+ and 90hz after the update I got only 3 to 4 hours SOT.
  6. Aaron2017
    KitKat Apr 21, 2021
    Could be up to 3-4 weeks
  7. kãräñ_90564
    Gingerbread Apr 21, 2021
  8. singhManpreet
    Eclair Apr 21, 2021
  9. saurabh2655
    what , I am bored using same os for 1 year hope update will come soon for my device
  10. singhManpreet
    Eclair Apr 21, 2021
    singhManpreet , via OnePlus 7T , Apr 21, 2021 :
    Not sure brother, what is the reason. You can do few things.
    #Clear the caches of your gallery app and update it again.
    #Check really photos are not backed up and it is getting it from cloud
    #Photos are in RAW format or not. It might cause lag , not sure about it
    #Option of RAM boost is enabled.
    If above options don't solve the problem. Reset the device
    If you don't want to reset use Google photos app.
    Thanks
    vigneshwaran. likes this.
  11. devourerOfBits80
    Honeycomb Apr 21, 2021
  12. dsmonteiro
    Community Consultant Staff Member Apr 21, 2021
    dsmonteiro , Apr 21, 2021 :
    If you tap that, you'll be able to update it. Google Play system updates can be installed separately from the system updates.
    ShreyasPatil_ likes this.
  13. kãräñ_90564
    kãräñ_90564 , via OnePlus 7T , Apr 21, 2021 :
    I tried to update but It said that device is up-to-date
  14. dsmonteiro
    That likely means that Google rolled back that update. In any case, you'll get it when it's available.
    domestoboto likes this.
  15. Nikskalani2599
    Donut Apr 21, 2021
    devourerOfBits80 likes this.
  16. kãräñ_90564
    It go back to February 2021, after I Hard reset my device through recovery, earlier it was on March 2021.
  17. NebulaOO
  18. dsmonteiro
    That's why I said that the update was likely rolled back.
  19. SunielShakya
    Froyo Apr 21, 2021
