256
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. Oksygen
    Gingerbread Apr 21, 2021
    Oksygen , via OnePlus 7T , Apr 21, 2021 :
    Why don't you use Oxygen Updater if you can't wait?
  2. taweewan
    Cupcake Apr 21, 2021
  3. Sano1994 , via OnePlus 7T Glacier Blue , Apr 21, 2021 :
    Hey I'm asking this to op team we r need offical update...
    And op team is not refer the 3rd party apps
    Thanks
  4. AndroidManiac
  5. Oksygen
    Op team will never give you an answer, so no point in asking here.
  6. Aaron2017
    KitKat Apr 21, 2021
    Aaron2017 , Apr 21, 2021 :
    You need to use a rollback build first, before you can install OS10. Follow this guide
    https://www.droidwin.com/rollback-oneplus-7-7t-pro-android-10-oxygenos-10/
    After this you should be on the last open beta based on OS10. Now just skip the setup process and ingnore the update the system will give you and download and install the last stable OS10 version via local upgrade
    ghostofcain likes this.
  7. RaraBunny
    Froyo Apr 21, 2021
    RaraBunny , Apr 21, 2021 :
    Has ascending ringtone been enabled in your device?
    I don't know how that could cause system sounds to decrease but try checking it out under dialer settings.
    Drasm19 likes this.
  8. Drasm19
    Ice Cream Sandwich Apr 21, 2021
    Drasm19 , Apr 21, 2021 :
    No, I've checked that.
    Seems like a few other members are facing this issue as well.
    Not a big issue, just that I miss the 'clack' sound that my device made, everytime I unlocked it.
    RaraBunny likes this.
  9. C1609762008948
  10. Solace0107
    Donut Apr 21, 2021
  11. RaraBunny
    Froyo Apr 21, 2021
    Try clearing cache from system apps such as screenshot and sounds, see if that helps.
    Drasm19 likes this.
  12. Drasm19
    Okay, thanks.
    I don't think that's going to work, since I've tried clearing cache from recovery.
    Let's see.
  13. Z3R007
    Z3R007 , via OnePlus 7T , Apr 21, 2021 :
    It needs a 5G connection with more than 1Gbps speed to reach you. Or the night lock downs due to Corona impacting its travel or it's testing your patience level.
    Anyways wear a mask when it arrives. Stay safe dear.
  14. Z3R007
    Since you have issues with your current SW version, use Oxygen updater to get the latest update. That is better than waiting for OTA update.
  15. Aaron2017
    KitKat Apr 21, 2021
    I've seen a lot of posts like this for both 7 and 7t series. I had this too with the initial OS11 update, when they gave me the wrong global rom. When i switched to EU it was back to normal, so maybe another rom related issue?
    Drasm19 likes this.
  16. Only7o
    Donut Apr 21, 2021
    Only7o , via OnePlus 7T Pro , Apr 21, 2021 :
    The 7t pro HD1913 EU is even better after upgrading from 11.0.0.0 to 11.0.0.2. I always have QHD + and 90Hz turned on, the battery from 100% to 15% lasts for the second time 9h40min on an active screen with WiFi turned on (browsing the Internet, YT, without playing games). All system applications and those installed from the store start in no time, and the UI system itself is clearly smoother than I had on the A10. The call quality is perfect, even system call recording works with the appropriate application I don't see any problems and I'm not going to go back to 10 anymore.
    flither likes this.
  17. G.prudhvi
  18. Z3R007
    Can't answer about final update as updates never settle. There will be updates coming until end of life of the model.
    But the current release is a stable release.
    Sano1994 likes this.
  19. Z3R007
    You will. Oxygen updater just pulls the update from official OnePlus mirror. So, no worries.
