286
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. SHIKARIII
    Froyo Apr 29, 2021
  2. kumaran7696
    Cupcake Apr 29, 2021
  3. G1619275116869
  4. LoneStar08
  5. bramgoodwin
    Gingerbread Apr 29, 2021
    bramgoodwin , via OnePlus 7T , Apr 29, 2021 :
    Review of Android 11.0.0.2 Upgrade...
    I have a OnePlus 7T, using @tmobile in San Francisco..Just updated to Android 11…Generally pleased with update…No phone killing bugs…7T works about the same as before the update…Some thoughts…
    *The update took 15 minutes from Download to Reboot…No issues during installations…All of my apps work as they did with A10…
    *The AOD works when charging your phone only…You get Time, Date, which moves around screen top to bottom.
    *The notification shade works as before, except media is now on top, with notifications on bottom..All notifications work fine as before…Some of the media, such as Google Podcasts, does not show up in notification window…Not sure how to fix it…
    *After update, my Nova Launcher would not stay as default Launcher…Rebooted a few times, now works fine.
    *No Lag in performance…Scrolling, app opening, app operation all work as before, as to say FAST!!
    *WIFI, Bluetooth work as before … Easy connection, no dropping on either..
    *Warp Charging same as before, except for the pause at 80%, then go to 100% later…Worked first time charged, but has not worked since…Battery Life same also before, which generally got me through day, averages 4-5 hours SOT…
    *I use SwiftKey as keyboard … Works as before generally, but some problem with emojis…Click on category, blank…Click on another emoji category, go back works…Some small bug with the keyboard…Not a killer, but annoying …
    *I use Google Photos as default…Also works fine, as well as editing, sharing etc…All the same as before …
    *About Phone has changed…Nothing terrible, just liked old look better…
    Generally, Android 11 works fine…Not a lot of changes in the consumer facing experience…Assume under the hood better security, smoother operation, more modern in general…This is my second OP update experience, as prior, updated my OP6 to Android 10, which also worked well.
    All this talk of doom, bricking etc, which comes with each upgrade in every forum has never happened to me…Maybe because I’m not a gamer, don’t root my phones, whatever, each of my Android or IOS upgrades over the last years, covering 10 “smart phones” and iPad has always been positive…Unfortunately, 98% of posts on @Reddit, on OP forums are all negative …
    My advice is to upgrade as soon as you can…If you have any questions I can answer through my experience, happy to help…Good luck upgrading to A11…🙏🏽
  6. V1590582335370
    V1590582335370 , Apr 29, 2021 :
    No update received for me. I am using a 7T. Everyone got updates. Is there issue with device. What is reason that I didn't receive any update?
  7. Nike89
    Nike89 , Apr 29, 2021 :
    How Long then will the wait continues for stable Android 11 🤔🤔 .
  8. juttuka.pavan
    Ice Cream Sandwich Apr 29, 2021
    juttuka.pavan , via OnePlus 7T , Apr 29, 2021 :
    For your hard work 🙏🏻🤗.
    bramgoodwin likes this.
  9. ANUNADH
    Froyo Apr 29, 2021
    ANUNADH , via OnePlus 7T , Apr 29, 2021 :
    Don't worry i also didn't get, they said like its a staged update so it will take tym to reach all users. But now they rolling the ota like we playing a music, if we intrested in that so we play it else we pause it, same like that they rolling and stoping rolling. If u want to get android 11 soon it is better to buy a new phn from good brand. OnePlus already loss it. Very bad approach from their side
    V1590582335370 likes this.
  10. Aaron2017
    Lollipop Apr 29, 2021
    Aaron2017 , Apr 29, 2021 :
    Nothing wrong with your phone, the way they roll out updates can take weeks or more to fully roll out to everyone
    Sam197 likes this.
  11. Vishnudev_vdk
    Froyo Apr 29, 2021
    Sam197, domestoboto and Lakshayrupela like this.
  12. Lakshayrupela
    Donut Apr 29, 2021
    Sam197 and GolfPlus like this.
  13. Lakshayrupela
    Donut Apr 29, 2021
    Sam197 likes this.
  14. Rockstarviibes
    Sam197 likes this.
  15. GolfPlus
    Eclair Apr 29, 2021
    GolfPlus , via OnePlus 7T , Apr 29, 2021 :
    My advice, don't update,. Stay on android 10. I wish I didn't update to 11
    Heat issue
    Battery drain faster than before
    WiFi is not stable
    But if you decide to update, I wish you are lucky not face the same problems as mine
    vuttamb and Lakshayrupela like this.
  16. utkarsh_14
    Sam197 likes this.
  17. Hasnain159
  18. Hasnain159
    Hasnain159 , via OnePlus 7T , Apr 29, 2021 :
    Please friends not updated for Oxygen 11.0.0.2 for the OnePlus 7T because battery daring problem is so irrataing.I am facing this problem and it's so irrating battery daring just 3.5 over... This is my suggestion..
  19. Kanna_thas
    Sam197 likes this.
