287
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. Sam197
    Jelly Bean May 1, 2021
    Aaron2017 likes this.
  2. J1577769579265
    Gingerbread May 1, 2021
  3. shergilluminati
    Cupcake May 1, 2021
  4. Jerine_P_George
    Cupcake May 1, 2021
    Jerine_P_George , via OnePlus 7T , May 1, 2021 :
    Hi team,
    I have updated my 7T to oxygen os 11.0.0.2. After that fingerprint scanner is not working. If I keep my finger on the screen it shows "fingerprint hardware is not available". I tried to delete all fingerprints and register again. But unable to register the fingerprints again - error is "Element is not successful". I have restarted the mobile couple of times but it doesn't work.
    Soupboy_siva7 likes this.
  5. XsubbuX
    Donut May 1, 2021
    XsubbuX , via OnePlus 7T , May 1, 2021 :
    The dark mode kinda greyish, it should be completely dark. Heating like hell & battery consumption increased after the update. Please fix this ASAP.
  6. Neha_Jain31
    Donut May 1, 2021
    Neha_Jain31 , via OnePlus 7T Pro , May 1, 2021 :
    After the new update, my wifi keeps disconnecting and reconnecting. I don't know what's the problem but it is very frustrating and I genuinely don't know how to fix it.
    shishirgupta2204 likes this.
  7. shishirgupta2204 , via OnePlus 7T Pro , May 1, 2021 :
    Same here ..I am using the 7t pro..charging speed as checked by Both Ampere and accubattery app shows low amps at low battery percentage.. for eg only 2500 mah in 33 percent battery. Battery drain and heating is very high..I am thinking of reverting back to oxygen os 10 but I will clear all data that's what stopping me
  8. shishirgupta2204 , via OnePlus 7T Pro , May 1, 2021 :
  9. G1535643126663
    Cupcake May 1, 2021
    G1535643126663 , May 1, 2021 :
    Android OS 11 sucks.. lots of issues.
    1. My WiFi getting disconnected itself and then reconnecting.
    2. Battery draining very fast.
    3. Slow opening of any folder
  10. Sam197
    Sam197 , via OnePlus Community App , May 1, 2021 :
    Do you have a router support 2 channels
  11. Neha_Jain31
    Donut May 1, 2021
    Same with point no. 1
    VigneshOnePlus7T likes this.
  12. Neha_Jain31
    Donut May 1, 2021
  13. Sam197
  14. Neha_Jain31
    Donut May 1, 2021
  15. Sam197
    Most likely,your phone can't stay in one of them ,so it keep connect and disconnect
    See if you delete one of them as your WiFi network it would solve the issue or not
    Plus turn off the intelgent network settings
  16. Neha_Jain31
    Donut May 1, 2021
    For now, this has actually resolved my issue. Hoping it continues. Thank you very much!
  17. Soupboy_siva7
    Eclair May 1, 2021
    Soupboy_siva7 , via OnePlus 7T , May 1, 2021 :
    I think you've cleared the cache memory... Try factory reset it works 👍🏻
  18. Sam197
    Neha_Jain31 likes this.
  19. antoniomancu_00
    Eclair May 1, 2021
    antoniomancu_00 , via OnePlus 7T , May 1, 2021 :
    Urgently update the OnePlus 7T, it's full of bugs, you're doing pity !! Fingerprint not working,battery discharge is very fast,temperature of device is very hot.
    STU CELLULARE FA DAVVERU CAC4RE
    kvnreddy and mogulaps like this.
