257
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. kãräñ_90564
    Gingerbread Apr 17, 2021
    nonseth likes this.
  2. AzureB1te
  3. Deepak Joshi S
    Cupcake Apr 17, 2021
    Deepak Joshi S , via OnePlus 7T , Apr 17, 2021 :
    Should needed to wipe the data?
  4. W1579967779066
  5. nonseth
    Donut Apr 17, 2021
  6. RohithViharsh
    Shinjan_Saha likes this.
  7. amitexe786
  8. D1600610555193
    Eclair Apr 17, 2021
    D1600610555193 , via OnePlus 7T , Apr 17, 2021 :
    Gaming me heat problem nayi he kya
  9. Gud9272
  10. D1600610555193
    Eclair Apr 17, 2021
  11. I1578251092729
    Donut Apr 17, 2021
  12. D1600610555193
    Eclair Apr 17, 2021
  13. KUMARATEJA
    KUMARATEJA , Apr 17, 2021 :
    Device: OP 7T
    The update is looking decent.
    1. Clear cache post updating. That will help for faster loading of apps.
    2. Post updating you will find phone getting heated up. But, don't worry heating persists for a while and vanishes off.
    3. The dark mode is looking like gray mode. Am I the only one who is experiencing this gray mode?
    4. The battery draining reduced comparatively. Still they can improve.
    5. If you pull down the notification bar in potrait mode, it doesn't come with 100% width like 00S 10.
    6. If you pull down the notification bar in landscape mode, you will find the instability of scroll down. The notification bar scrolls down either in center or on right side.
    7. The camera bugs also got fixed. But, as others I too faced the drop of video quality while playing post recording. Still they can improve.
    P.S: I have updated using Oxygen Updater App.
    Z3R007 likes this.
  14. D1600610555193
    Eclair Apr 17, 2021
  15. Aaron2017
    KitKat Apr 17, 2021
    Aaron2017 , Apr 17, 2021 :
    No, they made dark mode greyish. The notification panel is normal. It comes down either left or right depending from which side you swipe. It's part of the one hand design of OS11
    Sam197 likes this.
  16. KUMARATEJA
  17. Prakashlahare
    Donut Apr 17, 2021
  18. D1600610555193
    Eclair Apr 17, 2021
