268
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. D1600610555193
    Eclair Apr 17, 2021
  2. Gohil_Chirag
    Gingerbread Apr 17, 2021
  3. kãräñ_90564
  4. KUMARATEJA
    Cupcake Apr 17, 2021
  5. Abhishek029
    Froyo Apr 17, 2021
    Abhishek029 , via OnePlus 7T , Apr 17, 2021 :
    I didn't solve bro, I just turn on mannualy for which app it's needed.
    For example: I'm using android bubble notification on whatsapp and messenger.
    Simply turning on from that App's settings under notification settings>Bubble> android bubble on for all notification .
    This somehow working for me. Don't know if there any bug on any app specific. For above two app it's working fine for me.
  6. Abhishek029
    Froyo Apr 17, 2021
    If you're Shifting from any Beta - Stable or vice versa, data will gonna wipe.
    For your reference, whenever you're going to flash a new built through local upgrade, it'll show there if data wipe will happen on next step.
    If no such thing is showing then just don't worry nothing will be wiped. 🙂
    but I'll recommend you bro keep a backup then flash and always do a full factory reset.
  7. G1581692857466
    Eclair Apr 17, 2021
    G1581692857466 , via OnePlus 7T , Apr 17, 2021 :
    So far good. No issues in WiFi connectivity or battery backup. Recommended to update this version. I'm enjoying.
    bramgoodwin and ConnectMrMJ like this.
  8. kãräñ_90564
  9. M1579698710218
  10. Deepak1523
    Phoenix_ likes this.
  11. B1616162318266
  12. Drasm19
    Ice Cream Sandwich Apr 17, 2021
    Drasm19 , Apr 17, 2021 :
    This was helpful.
    Thanks!
    Abhishek029 and RaraBunny like this.
  13. RaraBunny
    Froyo Apr 17, 2021
    RaraBunny , Apr 17, 2021 :
    Are you able to connect 2.5ghz and 5ghz WiFi connections simultaneously?
  14. KartheekPakala
  15. Aswin08
    Honeycomb Apr 17, 2021
  16. MautikMehta
    Donut Apr 17, 2021
  17. MautikMehta
    Donut Apr 17, 2021
  18. H1593857037593
    Froyo Apr 17, 2021
    H1593857037593 , Apr 17, 2021 :
    I'm sorry but you really need to stop posting nonsense in this forum.
    There's absolutely nothing wrong with the updater.
    ghostofcain likes this.
  19. MoHiTsOoD,
    F_Akshay_Mhatre_CHZr likes this.
  20. tazzb93
    Eclair Apr 17, 2021
    tazzb93 , via OnePlus 7T , Apr 17, 2021 :
    Does anyone notice a reddish tint around the edges of section tabs in settings while scrolling..keeping dark mode and comfort vision ON.
