286
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. G_clement_roy_007 , via OnePlus 7T Frosted Silver , May 14, 2021 :
    I'm facing the same issue.... I'm unable to find any solution
  2. Y1577230642385
    Donut May 14, 2021
    Y1577230642385 , via OnePlus 7T , May 14, 2021 :
    Hey guys,
    I bought my Phone with an global Rom i dont know why my ota Update gave me an indian Rom. Maybe an Update issue. I used at last oxygen 10.3. 8.hd65aa. I had no problems with that Rom, i only had a heating / battery drain Problem since i used the indian Version.
    Yesterday i installed Android 11 oxygen 11.0.0.2 hd65ba european Version.
    Everything is working great no problems at all. 90hz is working without problem, no lags, no camera problem. Even the battery drain is getting better! The gallery is perfekly working!
    I have no problems Till now...
    The only Thing is the battery, it looks like that the battery needs a few charging cycles to work fine.
    Thats my experience Till now.
    IT looks really like the problems have something to do with the indian oxygen Updates.
    There is an issue/problem in it!
    Why you dont install the global/eu Rom? Wait till the indian oxygen Update is working! Doesnt it work on indian phones?
    I live in Germany i used at first the global oxygen, i had no problems everything Was working, i used the indian Version everything was working only the Phone getting Hot and battery drain. Is there a reason why the eu/global Version Not working in India? I think it has also to work in India! The only Problem would be that eu/global Rom dont Support languages from India. You have to use the English language in this case. But it will work.
  3. ArturSmirnov
    Cupcake May 14, 2021
    ArturSmirnov , via OnePlus 7T , May 14, 2021 :
    После обновления происходят самопроизвольные закрытия приложении и перезагрузки устройства
    Translation:
    After the update, the application closes spontaneously and the device reboots
  4. K1592453516429
    Froyo May 14, 2021
  5. PrithviChandra
  6. Totsquest
    Gingerbread May 14, 2021
    Totsquest , via OnePlus 7T Pro , May 14, 2021 :
    Pleased that 11 is working out for you. Most of all big thanks for sharing (positive post) your experience with everyone. I'd like to ask you "have you ever used OXYGEN UPDATER app for an update"...?
  7. Y1577230642385
    Donut May 14, 2021
    I never used oxygen Updater, allways useing Ota Updates. I installed Android 11 oxygen 11.0.0.2 eu manually. I downloaded the file and used lokal Upgrade.
    devourerOfBits80 likes this.
  8. Tamizh rtr
    Tamizh rtr , via OnePlus 7T , May 14, 2021 :
    After update my mobile was heating too much and charging speed is too slow...
    Some apps automatically foreclosed ...
    Oneplus wireless buds pairing problem ...
    Audio latency , sometimes single buds only paired..
  9. Aaron2017
    KitKat May 14, 2021
    Aaron2017 , May 14, 2021 :
    I have, almost always because i'm usually always last in queue to receive it OTA. It's the same update because they get the files straight from OnePlus servers, if that's what you're worried about.
  10. nehagupta.dun
    nehagupta.dun , via OnePlus 7T , May 14, 2021 :
    After the update, the phone battery is draining too fast, the phone is getting heated up too quickly, experiencing poor internet speed and connectivity. This is surely not helping and has messed up my oneplus 7T experience!
  11. C1578488810344
    C1578488810344 , via OnePlus 7T , May 14, 2021 :
    fock oneplus
    fock this company
    does elany mother focker test this updae (bug)
    camera app is bullshit
    portrait photos blur target instead background
    i take photo
    now i see all photos are broken
  12. Oneplus 9T
    Froyo May 14, 2021
  13. Only7o
    Eclair May 14, 2021
    Only7o , via OnePlus 7T Pro , May 14, 2021 :
    7T users seem to have the most problems. For me, everything works better on 7TPro than on Android 10, even the battery lasts much longer, on average it uses 10% per hour of the screen on, calmly 8.30-9h (100-15%). I don't play games but I tested different ones and they run smoothly. The phone never heats up excessively during normal use, but from what I've seen, the 7tpro model has an additional processor cooling tube.
    iamthespeedster likes this.
  14. Only7o
    Eclair May 14, 2021
    Click the Phone application - go to Call History - click the 3 dots next to the phone number you recorded the call - select the recording menu - there you will see the recording
    WFred likes this.
  15. Vikas_varma9545
    Eclair May 14, 2021
  16. Abdul B.
    OxygenOS Operations Staff Member May 14, 2021
    Stickied Post
    Abdul B. , May 14, 2021 :
    Hi friends,
    we are aware of some user feedback on the recent OxygenOS 11 update for the OnePlus 7T series and are working on system stability and battery performance improvements via upcoming OTAs. The next OTA will begin rolling out this month.
    Thank you for your support and we sincerely appreciate your feedback.
  17. parthsangvikar
    Donut May 14, 2021
    parthsangvikar , via OnePlus 7T , May 14, 2021 :
    Ya but recoding is not show in file manager.. record folder is showing empty
  18. viswanathdsfeb
    Froyo May 14, 2021
    viswanathdsfeb , via OnePlus 7T , May 14, 2021 :
    Please include network stability also
    Abhilash995 and devourerOfBits80 like this.
  19. Y1577230642385
    Donut May 14, 2021
    Good news! 👍👍👍
  20. Q1595954016286
    Froyo May 14, 2021
    Q1595954016286 , via OnePlus 7T , May 14, 2021 :
    Mainly improve speaker quality while taking calls
