286
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. Prashanth_396
    Cupcake Jun 21, 2021
  2. ghostofcain
    Marshmallow Jun 21, 2021
    ghostofcain , Jun 21, 2021 :
    Try the latest 11.0.1.1 build, this build has been deprecated. If your main issue is with the gallery, have you considered perhaps using a proper gallery app?
  3. AndroidManiac
    Honeycomb Jun 21, 2021
    AndroidManiac , via OnePlus 7T , Jun 21, 2021 :
    And OnePlus told me today to use 11.0.0.2 and not 11.0.1.1 to correct my Widevine L3 issue... So what do we know what's what? Seriously...
  4. Alex H. K.
    Froyo Jun 21, 2021
    Alex H. K. , Jun 21, 2021 :
    This is a big mockery !!!
    AndroidManiac likes this.
  5. Mizanur33
    Froyo Jun 24, 2021
    Mizanur33 , Jun 24, 2021 :
    before updating my op 7pro, i want to know the review of android 11 update in this device.help please.
  6. ghostofcain
    Marshmallow Jun 24, 2021
  7. Mizanur33
    Froyo Jun 25, 2021
    Alex H. K. likes this.
  8. ghostofcain
    Marshmallow Jun 26, 2021
    ghostofcain , Jun 26, 2021 :
    Help you with what? The picture quite simply explains your predicament. If after reading the pop up you are still in the dark, might I suggest, you shouldn't be trying to circumvent your carriers restrictions.
    I assume you have a T-Mobile USA handset? If so T-Mobile should be able to clue you in on the state of their update program, in the unlikely event your handset is not from T-Mobile, maybe the guys at oxygen updater have some kind of discord channel or email you could use to contact them?
    Shailender Sharma likes this.
  9. Lev4n
    Cupcake Jun 26, 2021
  10. ghostofcain
    Marshmallow Jun 28, 2021
  11. SameerTwelve
    Cupcake Jul 8, 2021
  12. SameerTwelve
    Cupcake Jul 8, 2021
    SameerTwelve , via OnePlus 7 , Jul 8, 2021 :
    Battery issue
    -Brightness issue
    -Ambient display issue
    -Gallery loading
    -Incoming caller notification was to late
  13. A1569634075556
    Gingerbread Jul 10, 2021
  14. N1590531280024
    Cupcake Jul 10, 2021
    N1590531280024 , via OnePlus 7T , Jul 10, 2021 :
    After update 11.0.0.2 After updating my oneplus 7t i am having a problem that when i make a call, call or message, after the message is sent, then the message displayed in it is on my mobile Stays the same for at least 15 to 20 minutes. It doesn't go away please fix it
  15. V Chandra Shekhar
    Donut Jul 26, 2021 at 3:46 PM
    V Chandra Shekhar , via OnePlus 7T , Jul 26, 2021 at 3:46 PM :
    Sir.. when we get AOD BITOMOJI UPDATE in ONEPLUS 7T and when we get next update sir
